I am looking for the best parts for this kind of amount to build, anybody can help would be really great full. Also if you could find a decent monitor with this build I might be able to stretch the budget to £600 with the monitor.
Thanks
atobe
Thanks
atobe
http://uk.pcpartpicker.com/p/WQywyc
CPU: AMD FX-6300 3.5GHz 6-Core Processor (£71.52 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£24.98 @ CCL Computers)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard (£64.00 @ Amazon UK)
Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory (£58.18 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£38.70 @ Aria PC)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card (£164.74 @ Scan.co.uk)
Case: Corsair 200R ATX Mid Tower Case (£44.99 @ Amazon UK)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply (£45.78 @ Amazon UK)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive (£9.58 @ Scan.co.uk)
Monitor: Hannspree HE225DPB 21.5" Monitor (£82.99 @ Ebuyer)
Total: £605.46
Looks great. +1 here.
If you are willing to get rid of the optical drive and add a few pounds you can get an IPS panel...
http://uk.pcpartpicker.com/part/lg-monitor-22mp55hqp
actually, having a gigabyte mobo on my computer I would say that the fan controller on them is really crappy (can't go under 10% on the pwm) and would prefer an asus m5a97 LE or EVO , the difference between the two is -+ 4£ from the original quote and the evo has more usb connectors, firewire, and a beefier power stage if you plan on overclocking or using a better processor anytime or need more usb ports/a firewire port/esata, otherwise the LE should be fine
edit : if you don't care about the mouse bios and the noise of your fans or plan on buying a fan controller, go for the gigabyte it has an extra pcie x1 port and a beefier power stage (also it lacks the e-sata and firewire from the m5a97 evo)
Wow this is great pick! Thanks very much!
The Gigabyte GA-970A-UD3P has a 8+2 power phase the asus mobo's do not have better 'beefier power stage' the LE has a unheatsinked 4+2 power phase and the EVO has a heatsinked 6+2 power phase.
The GA-970A-UD3P is a newer mobo less than a year old and has newer technology than the now very old asus mobo's (it allso has a point and click bios) i am asumeing you are mixing up motherboards and thinking of a differnt gigabyte mobo.
http://www.gigabyte.com/products/product-page.aspx?pid=4717#ov
