$50 over ear Headphones?
I currently have the Monoprice 8323's and they sound fine, however I can't wear them for more than an couple hours without my ears hurting, so as far as gaming goes I need a new set. So whats a good pair of headphones that are comfortable for gaming, and are durable (being portable would be a plus for use on the bus if they sound better than my current ones, however that's not necessary since I have headphones already)
 I've been eyeing the Audio Technica m-30's I just don't know how they feel. also the philips uptown, The Pianeer SE-A1000, and the Audio Technica Ath-t300.
Any opinions? Thanks in advance.
Well I love my Radioshack full size headphones (That's their actual name), they are nothing fancy and have a terrible build quality but for 20$ they're great.
how do the turtle beach sound?
Would not recommend turtle beach, their price to performance is a joke.
If you are restricted to big box stores, or just want to pick something up quickly to try, I recently bought some UE 4000 for my little brother. They go for 37$ on amazon.com. The styling is nice, but the sound is outstanding for the price. They are very premium feeling, the only drawback is they are on-ear, but I can wear them for hours and they feel just fine. They don't fold, but they come with a pouch and can withstand a drop, I would wear them on the tube or while playing some games.
The reviews for the ATH-M30 are also very good. They look nice, but i'd try and nab the ATH-M35s as they can fold, and would be great for a commute. These will far surpass any over-ear in the 50$ range.
Thanks I think I'm going to get the m35's, the reviews on amazon seem to say they are comfortable. Anyone have recommendations for a mic to add to it?
Here's some options that I've come up with that are relatively cheap (and will be on par with pretty much every gaming headset ever, modmic will make it a headset/headphones hybrid)
 The modmic looks really nice, but it's a expensive for your budget. I'd personally go for the zalman or audiotechnica, I'd go by the reviews (maybe search for some youtube reviews, sound tests).
I have a pair of these:
http://www.amazon.com/Razer-Electra-Over-Music-Headset/dp/B007R57KJA/ref=sr_1_1?ie=UTF8&qid=1390526621&sr=8-1&keywords=razer+electra+gaming+%26+music+headphones
I have a rather wide head, and wear glasses, and they don't pinch. Audio is good (though I've never owned super high end headphones) with decent bass and treble. Also, detachable cable, so you can theoretically replace the headphone cable when (not if) you finally have it fray internally.
I actually need to call Razer up and see if they don't have replacement cables available for sale.
This is a good option. Great sound for the price and comfortable too. Then just get a separate mic as well and you are set.
http://www.amazon.com/Panasonic-RP-HTF600-S-Stereo-Over-ear-Headphones/dp/B004MMEI8W/ref=sr_1_1?ie=UTF8&qid=1390526751&sr=8-1&keywords=panasonic+600
i have that audio technica mic, it's decent, gets the job done, i don't have to listen to it and nobody has told me to shut up because of my shitty mic so it's good enough for me, something to note is that i keep it clipped to my sony headphone cable, and the wire on this mic is so long that i need to coil it around the the headset cable 2-3 times to take up all the extra cable
I was looking at the M30's and the 8323's but those don't look comfortable at all lol. I ended up grabbing these a couple weeks ago:
Panasonic RP-HTF600-S
http://www.amazon.com/Panasonic-RP-HTF600-S-Stereo-Over-ear-Headphones/dp/B004MMEI8W/ref=sr_1_1?ie=UTF8&qid=1390525465&sr=8-1&keywords=Panasonic+RP-HTF600-S
They meet my needs but I think they could probably use a headphone amp to shine
Let us know how the M35's turn out
ue 4000 is 30 bucks on newegg right now.
Anyone know how the Philips uptown are,I figure I can pair it with the Audio Technica mic and call it good? and thanks for all of your responses.
here a link
Or maybe the razer don"t know.
Those philips have mixed reviews, I know philips as a generally cheap brand, I would avoid them unless you can find a review from an unbiased reviewer.
I had those razer headphones for a week, ended out returning. They really are for show, you have to go high up on the chain to get good razer cans.
If I were you I'd get the M35s (or maybe put in a bit more and get the golden M50s) and get the audiotechnica mic (it'll even match). Again, if you don't mind just on-ear, the UE 4000 are amazing, and really comfy, for just 30$, they sound 10x as good as beats (used as reference point because of popularity.
Alright thanks I'll be getting the m35's then.
I have one of those razers as well. I also have the superlux hd668b.
and they are considerably better in my opinion. The bass is better on the Razers, but the overall quality is way better on the superlux, and I would recommend the superlux to everyone for music and gaming, but there is a downside as the build quality is not the best and there is no mic. I do recommend spending $20 down the road to replace the ear-pads on the superlux with some brainwaves replacement. The velor gives a more open feeling sound (better for games and some music) which loses bass, and the leather feels better IMO and retains the same sound.
