Honestly if you want more performance overall the 4790k will do you "Great Justice" but if you are on a Budget the 8350 will be just fine. Thing AMD always have over intel is they have a product for every Budget Margin it's almost insane. you want an absurd CPU for the money the 8350 will do you fine. you need a CPU for that Budget PC, A $90 Ahtlon X4 860k exists lol. but in your case i'd just grab the 4790k you'll be fine good sir.
Hmm... if you out can afford a 4790 just save up an extra $150 or so and snag a 5820k. If you're tight on money snag the 8350. If you're into streaming it's actually better than the i7.
Easy, 4790k is the way to go. Its much newer and will therefore be much more worthy of future upgrades. The FX8350 is a great processor that many of us will never forget but it hasn't changed since 2012 and neither has its AM3+ socket. At this point in time and what your looking to do, the 4790k wiuld be a great choice.
