4770k vs 3770k For Gaming
Struggling to choose between these two processors for a gaming build. I have read through some benchmarks that the 3770k wins but the 4770k has the hyper-threading feature, which i know hardly any games even utilize but in future they may? Any advice on what processor i should get?
depends on ur budget if i had the money i would go for 4770k its more future proof ;)
Where I live the 4820K is cheaper than the 3770K and the 4770K. If you can get a cheap 2011 board this would be a really good option (in my opinion). The 3770K and the 4770K both have 4 cores and 8 threads (spelled that wrong). The 4770K runs a fair bit hotter than the 3770k and the performance difference is not that big. For overclocking I would really say the 3770K is the better option. Still I would stick with the 4820K with a X79A-GD45 Plus. Hope this was helpfull. Good luck building your rig!
klarkie,
Well i can get them for the same price, the 3770k is actually costing more
Well, they are both hyperthreaded. I believe all i7s are...
Performance between them is pretty similar. The 4770k will prob preform a tiny bit better, but in game you won't really notice much of a difference between the two parts.
The 4770k motherboards are cheaper, most of the time, and the Z87 chipset is better than the Z77 chipset and offers a bit more in terms of features.
Some say the Haswell parts don't overclock as well, but that seems to be up in the air with most people saying that there isn't that much of a difference when it comes to overclockability with it really coming down to how lucky you get in the silicon lottery.
Really though, if you are just gaming you don't need the i7. Unless you are gaming at 1440p, where the i7 does seem to perform better, than an i5 4670k will be just fine. That will save some cash.
Also, look at the FX-8350. It competes really well with the i7 in most games and in some productivity applications. I have one in my main rig and it destroys my 3570k.
While you could go Socket 2011, the 4820k in gaming doesn't really perform much better than the 4770k and sometimes it is actually worse. Really you are just buying the platform. While that many PCI-E lanes and quad channel RAM is nice, it is complete overkill for gaming. Plus, good X79 boards are quite expensive.
Yes like Asn said its all about budget if you can afford a 4770K get it, it has more features than the 3770K like more sata 3 without a Marvell controller and more PCI-E lanes, but the 3770K is still a solid chip and would recommend it too
Budget isnt a big issue due to them both being the same price, So whats the feeling all round? The 4770k?
Yes, go with the 4770k of you have decided to go down the i7 path.
A 4670k or an FX-8350 would also be fine for gaming and save you a bit. Your choice.
4770K and 3770K all i7´s are indeed HT.
Diffrences in gaming between these 2 cpu´s is not realy big, the reason why i should go for the i7-4770K is just because i would personaly not invest anymore in a dead platform.
FX8350 is indeed also a great choice.
Get a 4820KKK.
Just grab an i5. There's no difference between that and the gaming performance of an i7. The i7 is a productivity CPU first, and a gaming CPU last.
If you're set on Intel, go with a nice small form factor build. I would always recommend 4th gen i5 4670K over the old 3570k because it has some interesting motherboards and up-to-date features.
Still undecided :(
The gaming performance difference between the i5 and the i7 is nil, or within the margin of error. Either with the i5 having a slight advantage, or the i7 might be 1FPS faster
Seriously. Don't spend money for the sake of spending it. Balance the CPU with your needs.
Gaming = i5.
Choice of overclocking i5s are 3570k and 4670k. The 4670k is more up-to-date, and near enough the same price as the 3570k.
4670k should be your choice. Easy. Simple.
