40" 4k Monitor + 1080p vertical monitor
I'm looking for a pair of monitors that are going to complement each other.
Similar to this but with a single 40" 4K and secondary 1080p vertical monitor to place along side it. https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcT5R7pUarq9wT1JgCKnhO3NnxYNYle27Ryaqyr-JfjJdlldUlC5
Something with complimentary bezels and screen sizes is the priority and ultimately I recognize that I will have to get a 3rd party mounting system to achieve the full effect.
I cant be the only one who has been curious about this so what has worked for you guys or what have you come across and considered trying?
Also, do you think there is enough interest for a manufacturer to consider creating a perfect pairing for interested customers?
I believe that 1 23"or 24" 1080p screen will have very very close to the same PPI as a 40" 4k screen.
No idea about specific models that may go well together.
My 42" and 24" portrait displays work well together the screen height on both displays is very close so they look good together.
I still waiting for a high refresh 40-42" 4K display to upgrade the current 42" display.
@Marten Could I get a picture and/or some model names and numbers if it isn't to much trouble? Thanks!
There both old displays so not worth look at for purchasing. Its an LG 42" TV and a Dell 24" (about 8-10 years old and still running).
Really old pic when I was running windows like 2+ years ago. It shows how close they match.
