Hi all,
I’ve done a fair bit on research and am looking on getting a new workstation for 3D/adobe applications and a lot of GPU heavy 3D rendering and wanted to show you guys.
I know stock is very limited currently but just thinking about future expandability, is a 30xx 3/4 gpu set up even possible here? Guessing i’d need dual slot width/blower gpus right? And a bigger psu?
COOLERMASTER MASTERBOX NR600P MID TOWER CASE
AMD Ryzen Threadripper PRO 3955WX 16 Core CPU (3.9GHz - 4.3GHz, 72MB CACHE)
ASUS® Pro WS WRX80E-SAGE SE WIFI (Intel dual 10 G LAN, USB 3.2 Gen 2x2 Type-C port, SLI) (Pre-Order Only)
128GB Kingston DDR4 3200MHz ECC Registered (8 x 16GB)
Graphics Card - NONE, I ALREADY HAVE A GRAPHICS CARD
1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
CORSAIR 1600W PRO SERIES™ TITANIUM AX1600i DIGITAL MODULAR PSU
1 x 1 Metre IEC C19 UK Power Cable
PCS FrostFlow 200 TR4 Series High Performance CPU Cooler
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
2 x 10 GIGABIT ETHERNET PORTS
WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
NO OPERATING SYSTEM REQUIRED
If anyone gets a brief chance to look at this is there any concerns with compatibilty here?
Thanks all!
