3D Printed Modular Stackable mini-ITX Homelab
Some time ago I developed a modular stackable concept for a PC case that would allow me to use whatever components I had laying around (as long as it fits in 220x220x250mm, the build volume of my printer). The modules snap together magnetically (cause magnets are cool!) When I decided to get serious with my local AI infrastructure, I revamped the main case so it would fit a 2.5 slot GPU (RX 9060 XT with 16G VRAM). With the storage pricres exploding I was able to get my hands on some cheap used enterprise SAS HDDs. So I also integrated an HBA and build a NAS. Then things got out of hand and I acquired two nvidia V100 with 32 GB VRAM each connected via nvlink (using a cool Chinese backplane and some serious cooling). So the blue thing is not a subwoofer but the housing for the GPUs (I call it “Blue Scream”, as it has 4 10k fans and will live its life in the basement)…
The system on the lower left is the old design with less room, but I kept it compatible. The main compartment has room for a mini-ITX mainboard, a 2.5 slot PCIe card (as long as it is around 210 mm long), two 2.5” HDD or an HBA connected via M.2 adapter. There are PSU modules for ATX, SFX and flex ATX power supplies, then there is a module for front io, the disk shelves (using a cheap Chinese SAS/SATA backplane) and of course the V100 abomination. I plan to release the designs on printables. Let me know if you are interested so I will post the link.
Oh, just in case you wonder what the displays are: as another side project I built these status display showing CPU load (per thread and overall), CPU temp, network traffic as well as hostname and IP (they are based on WT32-SC01 Plus ESP32 module and scroll in real time)…
Very cool project!
Are the usb/audio front panels recycled from an exiting part, or custom made?
I’ve gone the other way, building one giant steel case to rule them all.
This is rad stacked on rad :sign_of_the_horns:t3:
Veeeeeery nice. Neatly done. Proper job!
That looks absolutely awesome. Great work :smiley:
