I have tried the settings AHC video demonstrated on my 3950x (Aorus Pro X570)
I notice the performance improvement with these settings, the processor is taking advantage of the thermal headroom I have.
My question is, is there a possibility of degrading my chip using these settings in long run? I do heavy VRAY animation renders with my machine and even on my lighter tasks regularly max out the CPU.
I saw some people saying that even auto PBO settings can sometimes degrade a chip.
As long as your voltage isn’t too high, I don’t see why your chip will degrade, if at all. Just make sure your VRMs are cool and the cpu itself gets adequate cooling.
Don’t worry about it (VRM). As for your cpu voltages, I’m not sure about that voltages the 3950X can run at, I wouldn’t worry about it at all, since AMD programmed it. Just keep your cpu package cool and you’re golden.
Thanks, yeah. I am quite rather happy with the performance of the system. I am getting 9518 in Cinebench R20 which should realistically represent the workload this baby will see , as I do 3D rendering using VRAY.
VRAY usually takes a long time right, in that case you usually see voltage spikes when you go from a low CPU usage state to a high state but it immediately drops if you sustain the load
So really all you have to worry about is if your VRM will explode or not
Thanks guys. I made a VRAY test with heavy scene with both the PBO and XFR turned on and those settings. And the difference was within margin of error, while the PBO and XFR turned on gave me 10C higher temps and much more power draw.
I think I will be totally satisfied with my 3950x with stock settings and with a quiet fan settings for my AIO.
Well yeah in certain workloads upping the pbo power limits could help some.
But honestly your mileage could vary from cpu to cpu.
I personally wouldn’t really bother with trying to overclock a 3900x or 3950x.
Because AMD pretty much already tweaked them to what they can do,
within stable marges.
The performance increase in most cases is just marginal at best.
So yeah i don’t really see much reasons to overclock them.
But pbo should basically be safe.
Because it should clock the cpu back as soon it’s hitting it’s thermal limits.
Ryzen simply does not overclock well at all.
So i wouldn’t really bother.
