I’m stumped.
I’m running TrueNAS SCALE ElectricEel 24.10 BETA which I updated within the past two weeks.
When I copy files FROM the system to any Windows 11 PC the speeds are good and normal. When I copy TO TrueNAS from my Windows 11 PC it transfers in kb/s. Starts at roughly 355 kb/s with bursts after about 30 seconds.
Things I’ve tried:
2x Fresh Windows 11 installs
2x Intel NICS
1x USB NICS
2X Wireless NICS
With multiple different drivers.
Network Reset etc.
Different IP address and DNS even though I have a manual lease in pfSense and used same settings on mint.
Then I tried Linux mint on the same PC and added the share. It worked completely fine copying to and from, both at expected speeds. So, it’s a Windows problem but I feel like this was only introduced after the electric eel update, though I can’t say that for sure since I didn’t test before the update.
Things I plan to try:
Playing with network settings (need suggestions)
Windows 10
Any suggestions and help us appreciated!
