So Im looking at getting a New PC to use this or my old PC (i7 3770k) as a Dedicated streaming/folding rig.
This is what I have currently:
PC Part Picker Link:http://pcpartpicker.com/p/2DImr
CPU: Intel Core i7-4930K 3.4GHz 6-Core Processor
Heatsink: Corsair H110 94.0 CFM Liquid CPU Cooler
MoBo: ASRock X79 Extreme6 (This is a placeholder, Im not sure what MoBo to get and I want your guys opinion)
RAM: G.Skill Trident X Series 16GB (4 x 4GB) DDR3-2400 Memory
SSD: Samsung 840 EVO 500GB 2.5" Solid State Disk or x2 250GB Versions because Ive heard that Windows 8 does better with 2 drives because of the backround processes that could also be running on the SSD and slowing the game down. (I alread have plenty of Hardrives laying around so I don't need to get a new one. Just a SSD)
GPU: EVGA GeForce GTX 780 Ti 3GB Video Card (x2 in SLI)
Case: Corsair 750D ATX Full Tower Case
DVD Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer (I will just be using this till I can transfer over my Bluray drive.
PSU: Corsair AX1200i (I already have the PSU, I am transfering it from my current build and will need to get a smaller PSU for my build to use it as a Streaming/ Folding PC)
Another thing I would need to know is what fans to get, Ive been looking at the Corsair SP's but I didnt see any that were 140mm. I am looking to do Push-Pull on my Cooler for fans. Also these are some fans I was looking at getting but they weren't on PC Part Picker that were recommended on another site I use.
bgears b-Blaster 140
http://www.newegg.com/Product/Product.aspx?Item=N82E16835132023&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6146846&SID=6ivnqwj5qy80
Anyway, budget can go up to $3750-$3850 but no higher than that, if you could keep it $3500 or below that would be great.
