Pros: audio quality input/output is good, mic on/off switch and mic has led indicator, seem to be pretty durable, nice looking (I guess, don’t actually care about this).
Neutral/con: you do need an adapter of some sort if you don’t have TRRS input - I had options already so neutral.
Con: large and kinda heavy - doesn’t actually have manual adjustment and the auto kinda sucks - maybe not a problem if you have a large/r head - I actually have to wear a hat for them to fit and cup my ears correctly - but I often do and I like everything else so didn’t return.
Thank you all so much, I did end up finding a $50 headset for $29 that I ended up getting. I will definitely keep a couple of those in mind when I’m looking for portable headphones to use when I’m traveling though!
Is there a name for the design on those where the part that goes in your ear is off to the side and angled like that(as opposed to dead center and straight)? What I’m currently using in place of my broken headset are the earbuds that came with my galaxy s10+ (they have the same design) and I absolutely love them because they stay in my ear perfectly. I’m going to need to replace these soon too as the left one stopped working a while ago, and the right one is likely to stop working soon too I’d imagine.
