A lot is wrong here LMAFO, you should go with a LGA2011 for this price range and for editing the full 6 cores with hyperthrading will help a lot and also get a 4GB GPU 670 or 680 for 3D editing and rendering, and fianly a 1000W PSU is way over kill for this build a 800W for the LGA 2011 with two 680s will do fine but 1000W for this is behond overkill even if you are watercooling it.
LGA1155 is just fine, although it is a dead socket.
So is 2011 basically.
1000w is overkill unless you're planning on quite a bit of upgrades. there's nothing wrong with room for expansion, but still. you could knock a few bucks off that and put the money towards ditching the air cooler and just getting a h100i or a kraken. I'd do that. Idk how set you are on overlocking, though.
I know about the cycle of dead sockets. Ivy bridge-E will be a dead socket in 2014 and so on. Intel runs on the tick tock cycle so death was right I should go with the tock. I already changed the psu to 850w. I know that water cooling is better but I have never really trusted it. What if the pipes burst or something of that nature?
