double check to make sure you don't have any Nvidia special options selected, like TXAA, PhysX ect. Still doesn't work check Raptor to see what are the recommended settings for your system.
Sounds like its bad optimization on AMD side probably have to keep an eye on updates when released. I remember playing Tomb Raider when it first came out on my GTX 650 Ti i had textures ultra and tressFX off 1080p 70 fps max TressFX on i was getting 7 fps max. I installed it again an hour ago since im poor to buy games now im getting 58 fps max with fress fx on.
Make sure that you don't have the passed drivers form your old GPU still installed and make sure that you have the beta amd drivers as they do solve a serveral issues including better graphics processing.
