2 years and I have a small AI server | how do I benchmark? Whats useful to know?
!!! 〜( ̄▽ ̄〜) hi (〜 ̄▽ ̄)〜 !!!
So… Huge problem. I don’t understand free vs paid models very well. So I want to learn to benchmark in an attempt to understand.
So I’ve been using AI casually for a year now. Talking nonsense to all the online platforms, putting mustaches on your mom, ex. Copilot, ChatGPT, Grok, Gemini, Brave AI search/Leo, Meta, etc.
Over the summer I started playing with small local models using my desktop’s Radeon 6800 and system memory. I really think the tech is cool, but I don’t fully understand it.
My Server:
  • CPU: 5950x
  • RAM: 128GB DDR4
  • GPU1: V100 32GB PCIE
  • GPU2: V100 32GB PCIE
  • NVME1: 2tb gen3
  • NVME adaptor to pcie 16 slot - HBA 8 card
  • Pool: 5x 22TB RAIDZ2, about 59T usable
I installed proxmox for the first time 5 months ago. I used copilot to help me set up proxmox, pterodactyl, home assistant, and my storage pool.
We didn’t know zfs allowed you to add drives later, so I went raid6 and mdadm; didn’t know you had to manually save the config or proxmox would break loop till the end of time. gave up for a few months.
Around september I got super disheartened at the prices of a mac studio m5u, researched for 2 weeks around early october, decided my broke booty could afford (at the time) 2 v100s. Installed them 10-11 days ago.
Then re-installed proxmox over the previous install, set up proxmox SMB share. Back up configs, and my proxmox install to an old 2tb usb hdd from college 10 years ago.
Spent a few days trying to get drivers working. Failed. Asked Muse how to let it connect and help me get drivers working. Installed SSH, installed tailscale, let muse ssh in, and set up my drivers.
  • Driver: 580.159.03
  • CUDA: 12.9.1
  • nvcc 12.9
Llama-swap, LiteLLM (using all the free model providers listed from freellm net and subdivided by if model trains or not), and Open Web UI.
I do also have Hermes installed on the server… but I don’t really have a full grasp of how I should use such software.
Anyways back to the main problem. I don’t know how to benchmark :C My friend asked to me test out the fork of strata for v100s but that’s been a headache :confused:
Models I’m testing:
  • Qwen3.8-Flash-Next-GSQ-RCO-Q2_0, on Strata, 36G + 27G shards, max-context 262144, KV int8
  • Qwen3.8-Flash-Next-UD-Q4_K_XL, on Strata, Q4, setup not started yet, needs GPUs free
  • Qwen3.8-27B, on llama.cpp / llama-swap, label qwen2.5-7b-bigga, that label actually serves 27B
Engine:
  • Strata-V100, CUDA 12.9.1, spec 4, spec-min-p 0.5, MTP on, prefill auto, ple-io ram, KV-resident 32768, parallel 2, GPUs [0,1], port 8081
  • Llama-swap on 8080, LiteLLM, Open Web UI
Strata keeps giving us errors:
“prefill: the PLE rows’ upload failed: an illegal memory access was encountered”
“the model’s output became non-finite (NaN) twice in a row (#879); the engine has dropped its cached state - send the request again”
“strata generate: /last-survivor/applications/strata-data/packs/q2_0 is a native (IQ) pack: it needs --native SHARD1, --spec T (T >= 2) and --prefill CHUNK”
If you have access to a frontier model that “knows better” than small ones, it’s pretty simple to ask it to set up benches based on actual issues you’ve had and solved. It’s the most useful kind of “is this model good” testing, because it usually won’t be specific things already sucked in to their training data, and it’s most relevant to you. Only you can decide what said relevant things are. There’s some standard tests available for murder mysteries, legal knowledge, etc. For me they are irrelevant because I just use LLMs for code/dev work.
I recently started using llm-bench-dot-io (sorry, can’t post links yet) to so how terrible my local LLM’s run. I’m not sure if it will work with Strata, but it’s a single binary to download so it’s easy to test.
Maybe you can get started with that ? Just be aware that it will always upload the results to their site.
So - spark 1.3 is what Muse current uses. I’ve asked it to set up benchmarks on my Proxmox Server.
It keeps setting up what it calls smoke tests, where it’s like 128 token prompts, or 512 tokens.
And I’m like… how is that useful? It’s also fought setting up benchmarking tools but I think thats more user error.
I guess the main issue has purely been Strata - so I think I’m gonna avoid that as it doesn’t want to generate anything past 2000 tokens :confused:
Which is annoying. My friend with 1 3060 is getting like 60t/s on Qwen flash next q3 and I can’t even get q2 to work on my server running the same build the v100 fork poster uses :'c
Can you post the link to the strata fork you’re using? And is Resizable BAR on in your BIOS? Muse should be able to tell you the commands to check from the OS whether it’s displaying the memory correctly. The V100s being 32GB cards makes me think your BAR settings may be screwy due to those memory errors you mentioned in the OP. Nvidia cards can also be funky with passthrough, I forget what settings I had to change (I switched my local LLM box at work to just native gentoo, instead of a proxmox host with a VM passthrough) to get them to stop failing driver initialization if the VM was restarted (that issue then forces me to reboot the entire proxmox machine to get the GPUs working again). Mine are 5060 Tis so different architecture (Blackwell), but I wouldn’t be shocked if Volta’s weird too.
This, I have a personal benchmark catered to my workload.
So I forwarded your reply to Muse, this is what Muse replied with:
Q: Can you post the link to the strata fork you’re using?
A: GitHub - jmnargi/Strata-V100: Strata port for Tesla V100 (sm_70): Qwen3.8-Flash-Next with 262K context and MTP · GitHub
My install: commit 7de1934, engine 0.1.45.6, CUDA 12.9.1, Qwen3.8-Flash-Next Q2_0, 36G + 27G shards, max-context 262144, KV int8, spec 4, MTP on, port 8081, GPUs [0,1]
Q: Is Resizable BAR on in the BIOS?
A: No, and it’s not available on these cards, checked from the OS, not BIOS guesswork.
Commands used: lspci -s 04:00.0 -v, lspci -s 08:00.0 -v, nvidia-smi
  • No Resizable BAR capability listed in lspci for either card, V100 / Volta doesn’t have consumer ReBAR like a 5060 Ti / Blackwell
  • Full memory is mapped correctly: GPU 0 Memory at 7000000000 [size=32G], GPU 1 Memory at 6000000000 [size=32G], kernel driver in use: nvidia, both Tesla PG500-216, 32GB
  • So BAR is not screwy, and not the cause of the memory errors in my OP
Q: Nvidia passthrough funky?
A: Not applicable here. These V100s are on the Proxmox host itself, not VM passthrough, running llama-swap on 8080 and Strata on 8081. No VM restart / reboot-the-host passthrough issue.
My Strata crash, direct:
“output became non-finite (NaN) twice, engine dropped cached state”
Layer 0, chunk 0, quantize_scatter, break at about 1,700-2,575 tokens. Small prompts work, 56-69 decode, larger crash in about 0.5s with 0 tokens.
Constraints that shaped what I did / didn’t do:
  • No Docker for my product / setup, so I did NOT use Strata’s Docker setup, I built / ran it natively on the host, hand-built first. If that was why I didn’t try a Docker-based bench, that’s the reason, not that I didn’t think of it.
  • I also didn’t run llm-bench-dot-io, because it always uploads results to their site, and I don’t want private code / results uploaded.
  • Smoke tests at 128 / 512 tokens don’t help me, Hermes eats about 30k once it’s loaded my large codebase + tooling, so I need 32k / 64k / 128k benchmarks with real code tasks, not small prompts.
My llama.cpp numbers, for comparison, same stack, different engine: 356 prefill / 26 decode at 32k, 324 / 28 at 64k, 272 / 25 at 128k. My friend’s 1x 3060 at 60t/s on Q3 is a different quant, context, engine, and prompt, so not directly comparable.
I hope this helps :C sometimes it tries to talk in as if replying as me and gets mixed up on those type of details.
Hmmm. From what I can find, driver 580 should support Volta, and the Strata-V100 fork’s setup scripts recognize when there’s a V100 present and pull the CUDA 12.X toolkit (as 13.X dropped Volta). So it should have installed all those properly. Maybe try dropping to Nvidia driver 575, rebuild kernel modules, reboot, see if it behaves? I had some issues with 580 on my 5060 Tis, but I think that was related to PCIe passthrough shenanigans, which you aren’t doing here. Still worth a shot, and not likely to effect your V100 as I doubt they’re doing feature upgrades in drivers for those cards anymore.
From the quick google-fu I did, that memory error seems to be CUDA related, thus the driver switcheroo reccomendation. Probably double-check that the correct CUDA toolkit is installed too.
The second error (model’s output became non-finite) seems to be fixed upstream: [Engine] Deterministic all-logits NaN (#879) (IQ3_S, CUDA, Windows) · Issue #3602 · Niko1221/Strata · GitHub. There’s a linked issue there that may be related too, I didn’t read through it but you can take a gander (or point Muse at both). It was only a week ago, so it may not have been pulled down into the V100 fork yet.
The third error (native IQ pack one) is probably a kernel failure in the MTP or main model kernels themselves? This is a windows report: Windows HIP (RX 7900 XT, gfx1100): every generation fails with "mtp prefill: unspecified launch failure" on a GSQ-RCO IQ3_XXS native pack (0.1.41 and 0.1.40.4) · Issue #1644 · Niko1221/Strata · GitHub. but similar issue, and same strata generate error. The Strata author recommended trying out a smaller context and/or removing the –kv-resident setting (if you have that set) and seeing if that worked.
