So I recently added a Level 1 dual monitor/dual computer DP 1.2 KVM (albeit, the one for thin clients - the similar DP 1.4 KVM was out of stock when I ordered IIRC). Both monitors are 1080P monitors, but they’re old enough that they don’t have a DP output, but I’m using a DVI=> DP cable to connect both monitors to the KVM. KVM => Desktop is a direct DP connection.
The desktop/KVM and laptop/USB side of things are working great, however, with Corsair TBT100 docking station (I think it’s product # CU-9000006-NA ), if I plug in either DVI cables from the KVM into the docking station, it sounds like Windows 10 is continually finding and dropping devices while the display on the laptop is flickering.
At this point, I’m not rightly sure if I’ve got a config issue, or if either the KVM or docking station need to change. Any help is greatly appreciated =)
