Hey guys, I'm putting together an entry-level gaming build as a gift so I need all the parts by Saturday 7/23 which means I need to order within the next 2 days.
Newegg has an Asus R9 380 4GB right now for $144.99 after MIR. I'm wondering if it would be worth the money saved to get this over the $200 RX 480 4GB (also since they likely will not be back in stock within the next 2 days).
What do you guys think? Is $145 still too much for a 4GB 380?
380 is almost 40% slower than 480... No competition. Even if the 4GB 480 is slightly slower, this is still 35% performance difference. If you can afford it - go 480...
RX 480. though they are not available on most e-tailers at the moment. the most you're going to find them at is at your local retailer. (Fry's, Microcenter even Best buy)
What resolution do you wanna game at ? With the price of 480 being so close, i think it is worth it.. With a basic 1080p monitor, if the money was tight a 380 would be fine ?
RX480s are priced above that $300 mark right now and still showing up as out of stock in a lot of places, even if some stores might have some on the shelf.
I have not yet seen a single RX480 priced at that $200 mark anywhere.. Older gen 4gb cards like the 380x are still priced at around $220. I have not seen a 380x for $145 anywhere either.
Expectation is that prices should drop but whether they actually are dropping or not is debatable.
ended up getting a Zotac 1060 mini for $247 shipped. I'd consider myself an AMD supporter but they really fucked themselves by failing to meet demand of 480. I was planning to upgrade to an 8GB 480 but ended up gifting my 280X and keeping the 1060 for myself because I'm selfish and impatient.
Yeah 1060 for some brands is priced around $250ish which is a good deal. I purchased myself a 380 from amazon since the price dropped to $150 and I felt that was ok for that particular card.
