1440p monitor?
Ive been looking around and so far im looking at the xstar DP2710 and the shimian qh270. Im open to options does anyone suggest something else? And yes im aware of the performance hit ill take.
Why do you want a 1440p monitor? You should get a 1080p one as they are better quality and you actually camt see some pixels on a 1440p monitor as I was doing some photoshop on one and then put it online to then notice on a different monitor that I has a giant line up the middle of it!
Isn't not being able to see pixels the point? That's why i got mine at least. It's on my Profile Page if you want a recommendation.
I was mistaken. I thought he wanted a 1440x900 monitor instead of a 2560x1440. Sorry its early :P and when I meant not being able to sea pixels I mean they actually were not their.
ASUS PB278Q is worth considering. It's much more expensive than the Korean panels, though.
Ah so it was like a missing row of pixels on the screen? That sounds like you could get confused with editing lol
I have two Asus PB278Q and are really happy with them, great picture and good colors and i can't notice any ghosting while playing FPS games.
