Hello,
I am currently looking for a new monitor to replace my main monitor (Currently a Samsung FX2490HD) I am looking for a 1440p monitor, so I can record/upload gameplay to YouTube in that resolution (since they have finally decided on a spec for 1440p video). The problem is, I would like to eventually expand this system to include additional monitors on one side or the other (perhaps both) I would like to have the side monitors be in portrait orientation. The reason I want portrait orientation is that I would like to use simple apps on the side monitors, such as TeamSpeak, Skype, Twitch chat, etc. I have no real interest in spanning games across multiple monitors.
My question for you guys is what monitors should I look at getting? Price is a bit of a concern, but it is not top priority. I am mostly concerned about getting monitors which will line up properly using the height resolution (the side monitors would in that case be 1440x900, or similar) I want both the top and bottom borders of the main monitor to line up with the left and right borders (top and bottom after being flipped). I hope that makes sense...
The monitor I am currently looking at is the Dell u2713HM monitor. I have not really found an appropriate monitor for the side monitors. Any suggestions you guys have would be amazing :)
Also sorry if the question is stupid, I don't know enough about monitors to really make judgement on them. Decided to register on the forums and ask guys who are more likely to know :)
**EDIT**
To clarify, I have selected a 1440P monitor that I like. I would either like to get a 1440*X monitor to go along side it in portrait mode, or I would like a suggestion for a better 1440p monitor and a 1440*X monitor to go with it. I picked the Dell one, because it seemed to have the best overall specs, and seems to be highly regarded in terms of its quality. I am open for suggestions if there are no 1440x900 (or similar) monitors that go well to match it.
