$1200 gaming pc build. What do you guys think?
get the FX-8320 instead of the FX-8150
10-15% better singlethreaded performance
also the 8320 runs cooler so you can get the 212+ cpu cooler instead, which costs less
hyper evo 212 cooler
http://pcpartpicker.com/part/mushkin-memory-996995 instead of corsair ram
psu: http://pcpartpicker.com/part/rosewill-power-supply-capstone650m   or   http://pcpartpicker.com/part/rosewill-power-supply-hive750
case: http://pcpartpicker.com/part/rosewill-case-blackbone
little bit cheaper mousepad: http://www.newegg.com/Product/Product.aspx?Item=N82E16826997036
nicer headset for the price: http://www.newegg.com/Product/Product.aspx?Item=N82E16826106632
cheaper 7870: http://pcpartpicker.com/part/diamond-video-card-7870pe52g     i used to be all obsessed with the HIS coolers
cheaper motherboard suggestions: http://pcpartpicker.com/part/asus-motherboard-m5a99xevo   or for nearly the same price as yours, http://pcpartpicker.com/part/asrock-motherboard-990fxextreme4
i'm just making suggestions of course, but really try and put more for a case!!
Spenlard recommendations are good.
my 2 cents: hate the case but it's all down to personal preferences ( theres much better cases in the 110$ price range)
I'd swap that hard drive for a western digital caviar blue.
