I can’t even recieve 1gbit with my synology ds without jumbo frames. maintains 680 to 700 but with jumbo frames it is 980 or so. 10gbit was working fine for quite a while without jumbo and now seems to be struggling.
Router/Firewall (Opnsense 2.5gb wan and 10gbit lan) > switch (CRS312-4C+8XG) from that switch i have my wifi access points, and 2.5gb switches x 3 for 2.5gbit devices. the 2.5 switches connect via 10gbit and have one 10gbit too.
But for some reason I am getting much lower than expected iper3 results. transferring from one 10gbit computer to another from ssd to ssd im seeing maybe 200 to 300 megabyte/s writes.
iperf3 with threads set to anything higher than 1 seems to hit max speed or close at 9.44gbit. But I am not seeing anywhere close to the those speeds for file transfers. 1gbit is more like 70MB/s and 10GBase-T is more like 150 to 200 MB/s.
What protocol?
With SMB, you may need to tinker with multi-path.
Are you doing a single, large file? Or copying a group of files? Cause with every transfer there is overhead, so you will get more bandwidth when copying a movie for example than a folder with a bunch of pictures in it.
File transfers also always work slower than iperf, as it runs through much more layers on both ends. That is why iperf really isnt a good test for anything except basic link connectivity
Single large. I did an experiment with a live disk of popos. Popos transfers nearly full bandwidth. iperf3 shows 9.6gigabit, it also transfers from ssd pool to ssd on system at 900MB/s. It seems to be a windows specific issue. Which is frustrating because I get maybe 200MB/s on any one connection except ones that use 1GBaseT.
I am dual booting at present and gonna run it that way until I can figure out what is going on with aquantia 10G and windows.
