10G MMF media converter/switch recommendation requested
Hi Folks,
I currently have my house and my barn connected via an underground run of multi-mode fiber (MMF). It is using simple 1Gb media converters at both ends, which works fine, but I am redoing all of the network for Devember using OpenWRT (Asus Zenwifi BT8 for those curious) AP/routers as well as 10G switches for wired connections at each end. My current expectation is that I will likely need to use something with SFP+ ports as essentially the media converters, I have no objection to it being an actual switch, but even just a media converter would work as I have unmanaged switches at each end and can use the OpenWRT devices for routing. What I don’t know is where does the bang for the buck currently reside for this use case. Any suggestions on inexpensive SFP+ capable devices I can use at each end of the MMF run would be greatly appreciated. Controlling cost is a high priority but there is room in the budget if necessary. I know the optics are going to be annoyingly pricey but that is just the way it is.
Thank you in advance for any suggestions!
Adding in the Devember link for additional context in case anyone wants it. Rebuilding a home network and adding in homelab services
I don’t think I’d say positively that I recommend them but there exist media converters for SFP+ to ethernet that do work from aliexpress. It’s probably the cheapest. Mine has worked for long enough to mention it, only bear in mind sfp+ modules aren’t all as plug and play and autosyncing as you might be used to -
A 10gbit rj45 module might sync out at 2.5 for the asus, it might not. a 2.5gbit rj45 sfp might not work in the converter.
Since you have the BT8 already I’d probably try it but i’d be thinking more ideally e.g. Zyxel XMG-108 has a SFP+ uplink 9at 10gbps) & 2.5gbit ethernet ports (PoE versions too, could be very interesting for e.g. ip cameras in your barn, & can power a suitable access point).
Thank you! To clarify, the 10G RJ45 will be going to a 10G switch, the architecture looks like this:
Cable Modem → Asus BT8 in house → 10G switch → fiber → 10G switch → Asus BT8 in barn and wired devices.
The goal is to have 10G links between buildings and on wired devices in each building, the BT8 in the barn will just be an AP, the one in the house will handle the network routing/DHCP/DNS. I might eventually add VLANs and more complex networking but for now a flat network is acceptable (and probably all that fits within my time and patience window ATM). The only thing I expect I would really need SFP+ for is the MMF, a device with 10Gbe and SFP+ is ideal but 2 SFP+ would work as well. I have used SFP+ professionally long long ago, I know they are (or were) coded optics and cheap ones were unreliable.
So you just need a MMF SFP+ receiver? You don’t need a media converter back to rj45 if you dont need to. lots of switches have both. If you have an SFP+ port free on your existing 10g switch you can buy a cheap receiver. I don’t know what specific brand you would be looking for but a lot of people seem to recommend FS.com for low end stuff if youre concerned about fakes on amazon. Theyre fairly cheap now, like $10-20 per receiver for low range ones, which it sounds like would capable enough for you, just gotta find the one compatible with your prexisting fiber.
If you don’t have any free ports maybe consider a cheap sfp+ switch. I think theyre undeer $100 for 4-8 port managed switches. If you havent already bought a 10g switch, just buy one that has 1-2 SFP+ ports in it natively and buy an SFP+ receiver so you can direct plug it in without having any converters in the way. less likely for something to go wrong that way too.
Absolutely, I want either a media converter capable of 10G or a 10G switch with at least one SFP+ port, ideally 2. What I don’t really know is what on the cheap end is worth a damn. Networking equipment has changed a lot since I last looked around at it.
I am considering this:
It doesn’t have the 10G-baseT ports I ideally want, but the price is great and supposedly has 60Gb/s backplane (which seems excessive given the port capacity). Amazon has them for less than $60 each which seems like a great price for what it is.
Yea theyre def a brand I see. Thats about right. 2.5g got super cheap, basically a few dollars more than gigabit.
If you’re ok witha chinese brand that teeters on the edge of being banned by the us government daily, TPlink/Omada is a very cheap way of getting some new stuff. they have a 40% off “upgrade” program where all you gotta do is upload a pic of any networking equipment and an email address. Their online us store is also weird and when I used it stacked with their new switches release a while ago so maybe take a look to see if it stacks with black friday ones.
If you want vlans being managed helps so Omada would help with that too. I think theyre basically all managed past gigabit
