Build is pretty good, except for the PSU. I modified your build a bit with a different Mobo, SSD, GPU, Case, PSU.
[url=http://pcpartpicker.com/p/QPjz]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/QPjz/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/QPjz/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/amd-cpu-fd8350frhkbox]AMD FX-8350 4.0GHz 8-Core Processor[/url] ($179.99 @ Newegg)
[b]CPU Cooler:[/b] [url=http://pcpartpicker.com/part/xigmatek-cpu-cooler-gaiasd1283]Xigmatek GAIA SD1283 56.3 CFM CPU Cooler[/url] ($19.99 @ Newegg)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asrock-motherboard-990fxextreme4]ASRock 990FX Extreme4 ATX AM3+ Motherboard[/url] ($139.99 @ Amazon)
[b]Memory:[/b] [url=http://pcpartpicker.com/part/gskill-memory-f317000cl11d8gbsr]G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory[/url] ($74.99 @ Newegg)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/samsung-internal-hard-drive-mz7td120bw]Samsung 840 Series 120GB 2.5" Solid State Disk[/url] ($99.89 @ Amazon)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd1002faex]Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive[/url] ($90.85 @ Amazon)
[b]Video Card:[/b] [url=http://pcpartpicker.com/part/sapphire-video-card-1003522l]Sapphire Radeon HD 7950 3GB Video Card[/url] ($269.99 @ Newegg)
[b]Case:[/b] [url=http://pcpartpicker.com/part/corsair-case-200r]Corsair 200R ATX Mid Tower Case[/url] ($59.99 @ Amazon)
[b]Power Supply:[/b] [url=http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9]XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply[/url] ($59.99 @ Newegg)
[b]Optical Drive:[/b] [url=http://pcpartpicker.com/part/lite-on-optical-drive-ihas124-04]Lite-On iHAS124-04 DVD/CD Writer[/url] ($14.99 @ Newegg)
[b]Total:[/b] $1010.66
[i](Prices include shipping, taxes, and discounts when available.)[/i]
[i](Generated by PCPartPicker 2013-04-15 05:48 EDT-0400)[/i]
* Mobo should be fine and is just a tad cheaper
* GPU is an upgrade from the GTX 660 Ti, but that is up to you if you want to change.
* SSD is a bit cheaper and is pretty quick. Tom's Hardware lists it as a good buy at ~$100
* The case is plenty for this budget. If you like the 300r or 500r you can get those too. Both are good buys, IMHO. I just like to spend more on the GPU, if possible, and by limiting the cost on a few parts one can do that. :)
* PSU is much better than your selection and about the same cost.
