$1,200 Build Help?
I'm looking for an Intel or AMD build that runs most games on high-ultra settings and supports eyefinity all uner $1,200. Any help?
http://pcpartpicker.com/user/armypig/saved/1wN4
How about http://pcpartpicker.com/user/ItsRemy/saved/#savedbuild_339774 disregarding the OS & monitors?
Nope. You have swaped out a very nice motherboard for an inferior one to buy a fancier case, which you will not be looking at while using the computer. The UD5 will allow you toget a much better overclock than the UD3.
