1-2 Upgrade. Mobo&CPU. FM2+ or AM3+?
Hey there, so I currently have an old AM3 Athlonx4 640 @3ghz.
I'm looking to upgrade it and I'm looking for opinions on the Socket and CPU I should go with.
So, First of all I game and occasionally stream. I run into problems real quickly while streaming any decent games where my CPU will completely max out and choke, requiring me to run with the worst settings possible everywhere and send out a low quality stream that still has issues of hanging and occasional chop.
I also putz around with GIMP and Blender, but these aren't major concerns as they run pretty smoothly and quickly as is with only very occasional hangs.
My confortable budget is between $200-$300 US. I can spend a bit over 300 if need be, but around $250 would be my ideal sweet spot.
I'm currently leaning towards AM3+ because my GTX570 is more than adequate still and the pure CPU options on the FM2 side aren't that huge of a step over my current CPU, at least from what i can gleam.
I don't see a compelling reason to go intel in this price range, the decent CPUs start at $200 and after a 212 cooler that leaves me with a really crappy mobo (Since intel mobos are as overpriced as their cpus imo).
The big reason I'm asking this is because this seems to be the last gen for AM3+ and while I'm not looking to upgrade within a year or two, it would be nice to not have to upgrade CPU and mobo twice.
So, Am I overthinking this and should just pick up a 6300/8320 or should i grab a 760x and go FM2+ to future proof just a tad?
Edit: I will be overclocking slightly and grabbing something like a 212 for cooling. Currently i have 4x4 1600 CAS9 RAM and a 750 80+ PSU so those aren't going to be an issue with any build.
Well since you are going to be streaming might as well go with an AM3 processor. The FX-8350 or 8320 (to save a few bucks) or $10 less and get the  FX-6350. Only reason why I see that the intel MOBO are more expensive is most likely due to the fact that the gold pins are on the motherboard opposed to AMD chips which have them on the processor itself.
No, it's really just inflation from demand on intel CPUs. The gold pins aren't all that expensive since they're plated in a few microns of gold.
I would get an AM3+ setup.  You're experiencing some CPU bottlenecking, and I don't think the FM2 platform can handle streaming too well, either.
http://pcpartpicker.com/p/mVBA
If you want to go cheaper, this would still work:
http://pcpartpicker.com/p/mFN6
But the Pro R2.0 is worth the extra ten or so bucks.
http://pcpartpicker.com/user/Maligned/saved/3H5L
So this is one I'm looking at currently, I could always change the 8320 to a 6300. I was considering a mATX build but all the AM3+ mATX mobos are based off the ancient 760 chipset.
Way to pick the same parts as me. XD
Yea, i understand the FM2+ wouldn't alleviate my bottleneck problem i was just considering it seeing as AM3+ seems almost EOL.
If you want to go smaller than ATX, you'll probably have to collect some cash and go Intel.
I would suggest you get the 8320, as the two cores will help with streaming over the 6300.
Yea, I decided on the 8320 and the ASUS Pro 2.0 990fx.
It was my first thought, I just wanted some other opinions and to see if anyone had any Intel suggestions in the price range or some compelling reason to go FM2+.
