ZRAM Proxmox on newer Mini PC's with DDR 5 memory
Anyone running ZRAM on Proxmox 8 hypervisor on a modern Mini PC with 96 GB RAM?
Given an AMD or Intel Mini PC with Crucial 96 GB DDR 5 Laptop Memory kit, i am wondering what would would be the sweet spot of ZRAM Swap amount and which compression option to use lzo, lzo-rle, lz4, lz4hc, or zstd.
  1. Running without ZRAM baseline
  2. What is the most amount of ZRAM swap we can add to a 96 GB DDR 5 mini pc with decent performance?
  3. What is the most amount of ZRAM swap we can add to a 96 GB DDR 5 mini pc with a stable system benchmark
Found some old online articles that claim a ZRAM swap of up to 8 GB can actually improve performance with the claim that the processor can decompress and compress the memory in real time. @wendell mentions this in a few YouTube Videos, but not entirely sure how to do a benchmark for this.
@wendell had a great youtube on the Bee-Link GTR7 Pro ( The GTR 7 is Amazing! But mine brokeā€¦) 11 months ago. I purchased one and upgraded to the 96 GB RAM crucial kit and also added 2 2TB 990 Samsung SSDs. I had a few bugs that were ultimately fixed in BIOS updates, in Proxmox 8.1 and also adding /etc/modprobe.d/zfs.conf. So now the system is very stable and performs well. Running Alpine Linux VMā€™s with docker that are all relatively lightweight on memory pressure. This system replaced and outperforms a Z440 HP Workstation with a Xeon 2690 CPU and Samsung 970 Pro NVME drives. This HP Workstation has 128 GB ECC DDR4 memory.
Be very cool if the GTR7 Pro could have a 32 GB ZRAM swap and see if it compares to a Xeon 2600 v4 generation server with 128 GB DDR4 memory.
ZRAM isnā€™t magical free performance ā€“ itā€™s faster than swapping to an NVMe, SSD or spinning rust, but itā€™s still memory activity managing the workload in place of crunching through your workload.
For me, questions 2 & 3 are the same, I donā€™t see any compromise to stability from having ZRAM swap. If your workload is sensitive or jittery because of swapping, itā€™s not batched up well and is reaching outside of a working set to other resources. Optimal batching would have all the necessary data and instructions ā€˜hotā€™ in RAM.
32GB of 96GB is 1/3, thatā€™s a reasonable amount for ZRAM. Find a compute task thatā€™s occasionally bottlenecked on file access, then share your results to see if thereā€™s an impact for 16GB, 24GB, 32GB and 48GB of ZRAM. (My config file says ā€œspeed: lz4 > zstd > lzoā€ and ā€œcompression: zstd > lzo > lz4ā€ so I tend to run zstd, if you want to compare lz4 and zstd, let us know if the lower speed but better compression is worth it in your testing.)
K3n.
How much ram are you actually using? Chances are you wonā€™t see any practical benefit to zram - you need memory pressure, have lots of compressible, inactive memory to make it worth it.
Iā€™ve got zswap on my hypervisor, and VMs are using 50% of the RAM. In the below stats, you can see Iā€™m saving ā€¦ 20 KiB of memory. Zooming!
ZSWAP KERNEL MODULE USAGE SUMMARY:
Pool: 0.03 MiB (0.0% of MemTotal).
Stored: 0.05 MiB (10.2% of SwapUsed).
Compression ratio: 1.86.
