Zotac Magnus EN980 - ZBOX Overview | Tek Syndicate
Check prices: Zotac Magnus EN980
Specs:
  • Processor
    Intel Core i5-6400 (quad-core 2.7GHz, up to 3.3GHz)
  • Chipset
    Intel
  • System Memory
    2 x DDR3L-1600 SODIMM Slots (up to 16GB)
 Graphics
  • Graphics Engine
    NVIDIA GeForce GTX 980 w/ 4GB GDDR5
  • Video Output
    2 x DisplayPort 1.2,
    2 x HDMI
 Storage
  • Hard Drive
    2.5“ SATA 6.0Gbps HDD/SSD bay
  • Mass Storage
  • Optical Drive
  • mSATA
    None
  • M.2
    M.2 SATA SSD slot (22/42,22/60,22/80)
  • Card Reader
    3-in-1 SD/SDHC/SDXC UHS-II
 I/O Ports
  • Audio
    Stereo output , Microphone
  • USB Port
    1 x USB 3.1 Type-C
    1 x USB 3.1
    4 x USB 3.0
  • LAN
    Dual 10/100/1000Mbps Ethernet
  • Antenna
    2 x WiFI SMA
  • Wifi
    802.11ac/b/g/n
  • Bluetooth
    Bluetooth 4.0
  • Legacy I/O
    None
  • CIR Infrared Port
    None
  • Expansion
    None
  • USB
    N/A
  • IDE
    N/A
  • VGA
    N/A
 Mechanical
  • Kensington Lock
    Yes
  • LED Indicators
    Power, HDD, WiFi
  • Power Supply
    2 x 19.5V/180W
  • Cooling system
    Liquid cooled
  • ZBOX Dimensions
    225mmx203mmx128mm
  • Case Mounting
    None
 Miscellaneous
  • Supported OS
    Windows 10 / 8.1 (32/64-bit)
  • Accessories
    2 x WiFi antenna
    2 x AC Adapter
    2 x Power Cord
    Warranty Card
    User Manual
    Quick Start Guide
    USB drive with O/S driver
    Driver Disc
This is a companion discussion topic for the original entry at https://teksyndicate.com/videos/zotac-magnus-en980-zbox-overview
The overview felt somewhat weak in coverage to be honest.
not enough things that you guys talked about
Nice review, more Steam box Linux machine goodness. The more you test Linux the easier it gets to work out a sound performance metric & use better tools. As for the machine, yea it needs DP1.3, hence a 1080/1070 like you guys said in the review, idc if it can all games at that refresh/resolution but the fact is next year 120hz 4k screens are out and about. DP 1.2 won't cut it.
I'm glad for the forums. The YouTube comments section has gotten pretty cancerous.
That might be the fugliest Mac I've ever seen.
Ahhhh.... the black front is rather... unfortunate. It makes it look like a tiny microwave oven.
Since the i5-6400 has an integrated GPU Unit, it would means that it should be possible to do GPU Passthrough with the 980 and use the Intel HD 530/5500 as the host GPU.
The question would be, does the Motherboard support VT-d ? And has anyone tried such a thing on that device ?
I have a theory why you couldn't keep your Z-Box...You haven't started with... wait for it
I respect that this channel hasn't sold out.
Oh yeah and this.
For $1600 no way I buy this.
Why they didn't make it all sand blasted black alluminum? In my opinion on the aesthetic they got it totally wrong. White, alluminum grey, black plastic and that baby blue mesh in the top...just ugly. Other than that I think the engineering behind such thing is pretty well done in my opinion. Since I don't know how difficult the engineering was I don't know if the price is justifiable or not, but surely it's pretty high. Maybe a watercooled build in a Fractal Nano S, for example, will cost kinda the same price I think (http://pcpartpicker.com/list/jTM4d6)
