Liked the video because I had a Zotac video card before & it was awesome. Now the thing is though with this card if it takes up two & a half pci-e slots what kind of board are you going to need & is there even one that is affordable that will allow you to SLI? Finally about it destroying a pci-e slot I assume one can easily jerry-rig this so the card is fine in the case. Now would it have been nice if Zotac designed this better & have had less weight with it? Yes.
I am wondering how it compares with a gtx 1080? I am just waiting for my Asus gtx 1080 turbo to deliver today. I would love to see a high end after market 1070 going up against its older brother.
To be honest, it would seem a little like epen. From what i have seen this card isnt really any faster than reference just runs cooler. If its only cooler, well then i would just get a 2 slot lighter card which will probably run almost as cool.
This card looks pretty badass. I'm a little apprehensive about Zotac's software utilities but if they have this much R&D budget to spend on their hardware, I'd wager their software to be very competent.
Hope I win, would be an awesome addition to mm 2.0. Although I wish the contest system was bit clearer, I thought the youtube system was used to check (I see the tek videos from the youtube subscriber feed first before I go to the site).
