I need a tool that can cut a very tight zip tie safely. :D
go anywhere like home depot or lowes maybe even a parts store and get some wire cutters. make sure you don't pick up wire strippers XD i did that once and got home to open the box and was like wtf is this?! O_O
safely. whats safer than a exacto knife, thats all i use, like u just got to be careful not to over cut and if possible, say if the zipties are around power cables i just try to cut at an angel were its not going into the wire
14'' steel shears would do the job.
[Joking]
off to buy a 14 inch steel shears :)
i have plastic model clippers (not sure what the real name is) they provide a close, clean cut, and the cutting area is small so you don't have to worry about cutting any wires
the one's i have are like the yellow ones here:
http://bp2.blogger.com/_J7CydK-jqGU/SCKuM10TDaI/AAAAAAAABi4/q5mMSHvrlbQ/s400/DSC08877.JPG
