Using ZFS to store my docker containers in Unraid.
I’m trying to hide all the ‘legacy’ datasets docker creates in the ZFS filesystem.
Main → ZFS Master → Normal mount points + lots of zfs mount points created by docker.
Settings → ZFS Master has a line labeled “Datasets Exlussion Patterns (Just One!);”
yes it is spelled that way.
My understanding is setting a pattern here will hide matching datasets from Main-> ZFS Master.
Here are some example datasets:
zfs-sas/docker/00ad8fb7c11513817d85c3948219b49b1266c627b0759bda2cad3d64d31d993f
zfs-sas/docker/01027d727bea33c6d52532ad62999e026047de0c0234917a9c2b0367bb0670ca|
Here is my pattern: ^zfs-sas/docker/.*
When I test this on regex and lua test sites it matches fine,
but it doesn’t seem to work for hiding all these docker datasets.
Am I misunderstanding how this works?
Or just doing something wrong with my pattern?
- Thanks for any help!
