I have a issue getting top speeds between my zfs array and my 10g nic and I don’t know why
can anybody enlighten me
i get 900 MB\s from ZFS RAM cash to PC RAM Disk (across a link between 2 NIC’s)
580 MB\s ish from array to M.2 SSD (internally within the server)
580 MB\s ish M.2 SSD to PC RAM Disk (across a link between 2 NIC’s)
but 200 MB\s if I’m lucky between the array and PC RAM Disk (across the link between 2 NIC’s)
hardware
2x 8GB RAM
2x ASUS XG-C100C NICs
1x Ryzen 5 3400G
1x MSI X470 GAMING PLUS MAX Motherboard
1x M.2 SSD
2x Ziyituod SATA 3.0 Card
10x 3TB WD red’s
Software
Ubuntu server
zfs raidz2
run an iperf test
size of files being transferred
What type of transfers are you using to see that speed?
SMB and stix files between 250mb and 500mb
Don’t have access to the server right now but will do tomorrow
That will be the best thing to get a baseline. ZFS performance can vary a good bit depending on what you’re doing.
Things I’d look into:
IOPS vs Throughput, 1 vdev will prioritize throughput over iops. Adding another raidz2 vdev will increase iops
Sync vs Async, I see you don’t have a SLOG so sync writes will suffer a slight penalty. Reads should be fine
fixed guess auto corrected to that idk
risk
September 2, 2020, 7:34pm
9
Could try transferring using socat.
I will run a iperf test tomorrow and get back to you 2 thanks for the help
Thanks for the suggestion will do
zlynx
September 3, 2020, 2:24am
13
Not that this is a problem exactly, but I am pretty sure that your M.2 SSD is a SATA drive. That 580 MB/s is right there where a M.2 SATA would be. I’m a little surprised that you didn’t go NVMe.
zlynx
September 3, 2020, 2:35am
14
Something to look for on the ZFS host machine with whatever tools you have. I like atop
and iostat
During the ZFS file transfer over the network look for bottlenecks. Is one or more of the drives at 100% IO Wait? Is one of the CPU cores at 100% Or similarly is your smbd
at 100%?
I did a iperf test and received 500-600 MBytes until i increased the simultaneous connections to 3 then it hit 1.05 GBytes
I am taking this to mean that it’s more a Samba/smb issue then a hardware issue
I might do in the future but it was just a case of cost I just needed a bigger drive at the time
for the redundant 2 drives and the space I would receive seemed like a good trade-off
