I’d like to start this off on a positive note :3
I said I’d never touch ZFS again but TrueNAS made quite for formidable offer (thanks ixSystems!) but that doesn’t mean it’s been a bumpy-less road but the TrueNAS and OpenZFS communities and their vast documentation have been absolutely helpful!
Now, onto what’s going on.
I needed to convert my RAIDZ2 4x16TB vdev to a mirrored 2x16TB vdev because I wanted to free up two drives for other projects and I wasn’t realistically going to occupy 16TB at breakneck speed.
So, I replicated the contents of the spinning disc vdev (creatively named tank) to my SSD-based vdev’s dataset for storing this data, moby/tank.
I ran replication on it and while tank was 2.26TB, moby/tank was 2.24TB and I cannot for the life of me figured out why.
I have no recollection what changed between my first and second attempts (they were both full filesystem replications) but somehow during my second attempt, the source and destination both matched 2.26TB so I called that a success and destroyed tank and recreated it.
Now comes the restoration and where the problems are starting to arise, I restore moby/tank/tank (the psudeo-root of the tank vdev is the tank dataset) to tank/tank and… now the sizes is mismatched.
2.26TB on moby/tank but 2.24TB on tank. I’ve heard of size increases due to mismatched compression parameters but this makes no sense to me, how does something shrink when it’s supposed to be a raw (because, encryption with post-replication decryption) full filesystem replication.
Here’s some stuff that makes it kind of confusing to me
> $ zfs list moby/tank moby/tank/tank moby/tank/proxmox -o name,logicalreferenced,logicalused,referenced,used
NAME LREFER LUSED REFER USED
moby/tank 86K 2.93T 314K 2.26T
moby/tank/tank 97.5K 2.88T 326K 2.21T
moby/tank/proxmox 84.5K 46.2G 279K 54.5G
> $ zfs list tank tank/tank tank/proxmox -o name,logicalreferenced,logicalused,referenced,used
tank 86K 2.93T 240K 2.24T
tank/tank 99K 2.88T 272K 2.20T
tank/proxmox 84.5K 46.2G 216K 42.7G
The logical used is the same, the refer is almost the same (a slight increment, even) but refer and used have gone down… after a raw transfer?
I’ve looked at the snapshot directories and don’t see a reduced number of snapshots so, what gives?
The only property difference I can think of that comes to mind is that tank (and its descendents) have read-only disabled and moby/tank is still read-only. I have attempted replications four or five times with the exact same results.
What’s going on?
