Tnx for the replies!
I did not modify any pool configs.
I created pool with ashift=12, -m /mnt/tank using by-id
zfs set compression=lz4 tank
zfs set atime=off tank
zfs create tank/datasets
ZFS was installed with simply: sudo apt install zfsutils-linux
Smart data reads Ok with no values changing.
Have not run memtest yet. Brand new system.
I can’t rule out the Sata cables, they are brand new. I just bought a set of 8 to hopefully avoid any issues like this.
Got some dmesg of the issue below:
[ 6679.593626] ahci 0000:29:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x7fffff00000 flags=0x0000]
[ 6679.593636] ahci 0000:29:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x7fffff00780 flags=0x0000]
[ 6710.900139] ata3.00: exception Emask 0x0 SAct 0x8800 SErr 0x40000 action 0x6 frozen
[ 6710.900143] ata3: SError: { CommWake }
[ 6710.900146] ata3.00: failed command: WRITE FPDMA QUEUED
[ 6710.900150] ata3.00: cmd 61/90:58:d0:98:bc/07:00:c4:01:00/40 tag 11 ncq dma 991232 out
res 40/00:01:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 6710.900152] ata3.00: status: { DRDY }
[ 6710.900153] ata3.00: failed command: WRITE FPDMA QUEUED
[ 6710.900157] ata3.00: cmd 61/00:78:20:a6:bc/03:00:c4:01:00/40 tag 15 ncq dma 393216 out
res 40/00:ff:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 6710.900158] ata3.00: status: { DRDY }
[ 6710.900161] ata3: hard resetting link
[ 6710.900185] ata4.00: exception Emask 0x0 SAct 0x800a0094 SErr 0x40000 action 0x6 frozen
[ 6710.900190] ata4: SError: { CommWake }
[ 6710.900192] ata4.00: failed command: WRITE FPDMA QUEUED
[ 6710.900197] ata4.00: cmd 61/b0:10:b0:9a:bc/07:00:c4:01:00/40 tag 2 ncq dma 1007616 ou
res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 6710.900199] ata4.00: status: { DRDY }
[ 6710.900200] ata4.00: failed command: WRITE FPDMA QUEUED
[ 6710.900203] ata4.00: cmd 61/a8:20:08:93:bc/07:00:c4:01:00/40 tag 4 ncq dma 1003520 ou
[ 6710.900205] ata4.00: status: { DRDY }
[ 6710.900206] ata4.00: failed command: WRITE FPDMA QUEUED
[ 6710.900209] ata4.00: cmd 61/58:38:20:aa:bc/05:00:c4:01:00/40 tag 7 ncq dma 700416 out
res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 6710.900211] ata4.00: status: { DRDY }
[ 6710.900212] ata4.00: failed command: WRITE FPDMA QUEUED
[ 6710.900215] ata4.00: cmd 61/c0:88:60:a2:bc/07:00:c4:01:00/40 tag 17 ncq dma 1015808 ou
[ 6710.900217] ata4.00: status: { DRDY }
[ 6710.900218] ata4.00: failed command: READ FPDMA QUEUED
[ 6710.900222] ata4.00: cmd 60/08:98:68:a0:bb/00:00:76:01:00/40 tag 19 ncq dma 4096 in
[ 6710.900223] ata4.00: status: { DRDY }
[ 6710.900224] ata4.00: failed command: WRITE FPDMA QUEUED
[ 6710.900228] ata4.00: cmd 61/88:f8:00:f9:ba/07:00:c4:01:00/40 tag 31 ncq dma 987136 out
res 40/00:00:00:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 6710.900229] ata4.00: status: { DRDY }
[ 6710.900232] ata4: hard resetting link
[ 6720.900535] ata4: softreset failed (1st FIS failed)
[ 6720.900539] ata4: hard resetting link
[ 6720.900630] ata3: softreset failed (1st FIS failed)
[ 6720.900635] ata3: hard resetting link
[ 6730.900224] ata4: softreset failed (1st FIS failed)
[ 6730.900229] ata4: hard resetting link
[ 6730.900826] ata3: softreset failed (1st FIS failed)
[ 6730.900831] ata3: hard resetting link
[ 6765.900445] ata4: softreset failed (1st FIS failed)
[ 6765.900452] ata4: limiting SATA link speed to 3.0 Gbps
[ 6765.900453] ata4: hard resetting link
[ 6765.900656] ata3: softreset failed (1st FIS failed)
[ 6765.900662] ata3: limiting SATA link speed to 3.0 Gbps
[ 6765.900664] ata3: hard resetting link
[ 6770.900559] ata3: softreset failed (1st FIS failed)
[ 6770.900566] ata3: reset failed, giving up
[ 6770.900568] ata3.00: disabled
[ 6770.900601] sd 2:0:0:0: [sdb] tag#11 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900603] sd 2:0:0:0: [sdb] tag#11 Sense Key : Not Ready [current]
[ 6770.900606] sd 2:0:0:0: [sdb] tag#11 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900608] sd 2:0:0:0: [sdb] tag#11 CDB: Write(16) 8a 00 00 00 00 01 c4 bc 98 d0 00 00 07 90 00 00
[ 6770.900611] blk_update_request: I/O error, dev sdb, sector 7595661520 op 0x1:(WRITE) flags 0x700 phys_seg 16 prio class 0
[ 6770.900614] ata4: softreset failed (1st FIS failed)
[ 6770.900619] ata4: reset failed, giving up
[ 6770.900623] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=2 offset=3888977649664 size=991232 flags=40080c80
[ 6770.900626] ata4.00: disabled
[ 6770.900637] sd 2:0:0:0: [sdb] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900638] sd 2:0:0:0: [sdb] tag#15 Sense Key : Not Ready [current]
[ 6770.900640] sd 2:0:0:0: [sdb] tag#15 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900641] sd 2:0:0:0: [sdb] tag#15 CDB: Write(16) 8a 00 00 00 00 01 c4 bc a6 20 00 00 03 00 00 00
[ 6770.900642] blk_update_request: I/O error, dev sdb, sector 7595664928 op 0x1:(WRITE) flags 0x700 phys_seg 6 prio class 0
[ 6770.900646] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=2 offset=3888979394560 size=393216 flags=40080c80
[ 6770.900651] ata3: EH complete
[ 6770.900697] sd 3:0:0:0: [sdc] tag#2 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900700] sd 3:0:0:0: [sdc] tag#2 Sense Key : Not Ready [current]
[ 6770.900702] sd 3:0:0:0: [sdc] tag#2 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900704] sd 3:0:0:0: [sdc] tag#2 CDB: Write(16) 8a 00 00 00 00 01 c4 bc 9a b0 00 00 07 b0 00 00
[ 6770.900707] blk_update_request: I/O error, dev sdc, sector 7595662000 op 0x1:(WRITE) flags 0x700 phys_seg 17 prio class 0
[ 6770.900713] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=3888977895424 size=1007616 flags=40080c80
[ 6770.900727] sd 3:0:0:0: [sdc] tag#4 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900729] sd 3:0:0:0: [sdc] tag#4 Sense Key : Not Ready [current]
[ 6770.900730] sd 3:0:0:0: [sdc] tag#4 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900732] sd 3:0:0:0: [sdc] tag#4 CDB: Write(16) 8a 00 00 00 00 01 c4 bc 93 08 00 00 07 a8 00 00
[ 6770.900733] blk_update_request: I/O error, dev sdc, sector 7595660040 op 0x1:(WRITE) flags 0x700 phys_seg 17 prio class 0
[ 6770.900736] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=3888976891904 size=1003520 flags=40080c80
[ 6770.900741] sd 3:0:0:0: [sdc] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900742] sd 3:0:0:0: [sdc] tag#7 Sense Key : Not Ready [current]
[ 6770.900744] sd 3:0:0:0: [sdc] tag#7 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900745] sd 3:0:0:0: [sdc] tag#7 CDB: Write(16) 8a 00 00 00 00 01 c4 bc aa 20 00 00 05 58 00 00
[ 6770.900746] blk_update_request: I/O error, dev sdc, sector 7595665952 op 0x1:(WRITE) flags 0x700 phys_seg 13 prio class 0
[ 6770.900749] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=3888979918848 size=700416 flags=40080c80
[ 6770.900754] sd 3:0:0:0: [sdc] tag#17 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900756] sd 3:0:0:0: [sdc] tag#17 Sense Key : Not Ready [current]
[ 6770.900757] sd 3:0:0:0: [sdc] tag#17 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900758] sd 3:0:0:0: [sdc] tag#17 CDB: Write(16) 8a 00 00 00 00 01 c4 bc a2 60 00 00 07 c0 00 00
[ 6770.900760] blk_update_request: I/O error, dev sdc, sector 7595663968 op 0x1:(WRITE) flags 0x4700 phys_seg 16 prio class 0
[ 6770.900762] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=3888978903040 size=1015808 flags=40080c80
[ 6770.900767] sd 3:0:0:0: [sdc] tag#19 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900769] sd 3:0:0:0: [sdc] tag#19 Sense Key : Not Ready [current]
[ 6770.900770] sd 3:0:0:0: [sdc] tag#19 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900772] sd 3:0:0:0: [sdc] tag#19 CDB: Read(16) 88 00 00 00 00 01 76 bb a0 68 00 00 00 08 00 00
[ 6770.900773] blk_update_request: I/O error, dev sdc, sector 6286975080 op 0x0:(READ) flags 0x700 phys_seg 1 prio class 0
[ 6770.900775] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=1 offset=3218930192384 size=4096 flags=180880
[ 6770.900781] sd 3:0:0:0: [sdc] tag#31 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6770.900782] sd 3:0:0:0: [sdc] tag#31 Sense Key : Not Ready [current]
[ 6770.900783] sd 3:0:0:0: [sdc] tag#31 Add. Sense: Logical unit not ready, hard reset required
[ 6770.900785] sd 3:0:0:0: [sdc] tag#31 CDB: Write(16) 8a 00 00 00 00 01 c4 ba f9 00 00 00 07 88 00 00
[ 6770.900786] blk_update_request: I/O error, dev sdc, sector 7595555072 op 0x1:(WRITE) flags 0x700 phys_seg 16 prio class 0
[ 6770.900788] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=3888923148288 size=987136 flags=40080c80
[ 6770.900795] ata4: EH complete
[ 6770.900814] sd 3:0:0:0: [sdc] tag#29 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 6770.900818] sd 3:0:0:0: [sdc] tag#29 CDB: Read(16) 88 00 00 00 00 00 00 00 0a 10 00 00 00 10 00 00
[ 6770.900820] blk_update_request: I/O error, dev sdc, sector 2576 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6770.900825] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=1 offset=270336 size=8192 flags=b08c1
[ 6770.901029] sd 3:0:0:0: [sdc] tag#23 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 6770.901031] sd 3:0:0:0: [sdc] tag#23 CDB: Read(16) 88 00 00 00 00 03 a3 80 e4 10 00 00 00 10 00 00
[ 6770.901032] blk_update_request: I/O error, dev sdc, sector 15628035088 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6770.901034] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=1 offset=8001552916480 size=8192 flags=b08c1
[ 6770.901039] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=3888981610496 size=65536 flags=180880
[ 6770.901040] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=1 offset=8001553178624 size=8192 flags=b08c1
[ 6770.901063] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=2 offset=3888980852736 size=823296 flags=40080c80
[ 6770.901075] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=2 offset=3888979853312 size=999424 flags=40080c80
[ 6770.901086] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=1 offset=270336 size=8192 flags=b08c1
[ 6770.901089] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=1 offset=8001552916480 size=8192 flags=b08c1
[ 6770.901091] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=1 offset=8001553178624 size=8192 flags=b08c1
[ 6770.901107] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=2754595639296 size=118784 flags=40080c80
[ 6770.901166] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00M9AA0_VAGLBL5L-part1 error=5 type=2 offset=3888980619264 size=991232 flags=40080c80
[ 6770.901179] zio pool=tank vdev=/dev/disk/by-id/ata-WDC_WD80EMAZ-00WJTA0_7HK2ANTN-part1 error=5 type=1 offset=3218930192384 size=4096 flags=180880
[ 6770.977087] WARNING: Pool ‘zfs16tb’ has encountered an uncorrectable I/O failure and has been suspended.
[ 6889.040711] INFO: task txg_sync:13072 blocked for more than 120 seconds.
[ 6889.040716] Tainted: P OE 5.3.0-22-generic #24+system76~1573659475~19.10~26b2022-Ubuntu
[ 6889.040717] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 6889.040718] txg_sync D 0 13072 2 0x80004000
[ 6889.040721] Call Trace:
[ 6889.040728] __schedule+0x2b9/0x6c0
[ 6889.040730] schedule+0x42/0xb0
[ 6889.040732] schedule_timeout+0x152/0x2f0
[ 6889.040792] ? spa_taskq_dispatch_ent+0x4f/0x70 [zfs]
[ 6889.040795] ? __next_timer_interrupt+0xe0/0xe0
[ 6889.040797] io_schedule_timeout+0x1e/0x50
[ 6889.040803] __cv_timedwait_common+0x15e/0x1c0 [spl]
[ 6889.040805] ? wait_woken+0x80/0x80
[ 6889.040810] __cv_timedwait_io+0x19/0x20 [spl]
[ 6889.040865] zio_wait+0x11b/0x230 [zfs]
[ 6889.040918] ? __raw_spin_unlock+0x9/0x10 [zfs]
[ 6889.040963] dsl_pool_sync+0xbc/0x410 [zfs]
[ 6889.041011] spa_sync_iterate_to_convergence+0xe0/0x1c0 [zfs]
[ 6889.041052] spa_sync+0x312/0x5b0 [zfs]
[ 6889.041099] txg_sync_thread+0x279/0x310 [zfs]
[ 6889.041143] ? txg_dispatch_callbacks+0x100/0x100 [zfs]
[ 6889.041149] thread_generic_wrapper+0x83/0xa0 [spl]
[ 6889.041152] kthread+0x104/0x140
[ 6889.041157] ? clear_bit+0x20/0x20 [spl]
[ 6889.041159] ? kthread_park+0x80/0x80
[ 6889.041161] ret_from_fork+0x22/0x40
[ 7009.873466] INFO: task pool-org.gnome.:20659 blocked for more than 120 seconds.
[ 7009.873470] Tainted: P OE 5.3.0-22-generic #24+system76~1573659475~19.10~26b2022-Ubuntu
[ 7009.873471] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 7009.873473] pool-org.gnome. D 0 20659 14714 0x80000000
[ 7009.873475] Call Trace:
[ 7009.873482] __schedule+0x2b9/0x6c0
[ 7009.873522] ? arc_space_return+0xa0/0x120 [zfs]
[ 7009.873525] schedule+0x42/0xb0
[ 7009.873526] io_schedule+0x16/0x40
[ 7009.873532] cv_wait_common+0xdc/0x180 [spl]
[ 7009.873534] ? wait_woken+0x80/0x80
[ 7009.873539] __cv_wait_io+0x18/0x20 [spl]
[ 7009.873597] txg_wait_synced+0x88/0xd0 [zfs]
[ 7009.873639] dmu_tx_wait+0x1b5/0x210 [zfs]
[ 7009.873677] dmu_tx_assign+0x49/0x70 [zfs]
[ 7009.873731] zfs_write+0x425/0xd50 [zfs]
[ 7009.873733] ? __switch_to_asm+0x40/0x70
[ 7009.873735] ? __switch_to_asm+0x34/0x70
[ 7009.873737] ? __switch_to_asm+0x40/0x70
[ 7009.873738] ? __switch_to_asm+0x34/0x70
[ 7009.873740] ? __switch_to_asm+0x40/0x70
[ 7009.873741] ? __switch_to_asm+0x34/0x70
[ 7009.873742] ? __switch_to_asm+0x40/0x70
[ 7009.873744] ? __switch_to_asm+0x40/0x70
[ 7009.873746] ? __switch_to_asm+0x34/0x70
[ 7009.873748] ? __switch_to+0x110/0x470
[ 7009.873749] ? __switch_to_asm+0x40/0x70
[ 7009.873752] ? find_get_entry+0x58/0x140
[ 7009.873803] zpl_write_common_iovec+0xad/0x120 [zfs]
[ 7009.873804] ? pagecache_get_page+0x2d/0x2f0
[ 7009.873807] ? touch_atime+0x33/0xe0
[ 7009.873853] zpl_iter_write_common+0x8e/0xb0 [zfs]
[ 7009.873898] zpl_iter_write+0x56/0x90 [zfs]
[ 7009.873901] new_sync_write+0x125/0x1c0
[ 7009.873903] __vfs_write+0x29/0x40
[ 7009.873904] __kernel_write+0x54/0x110
[ 7009.873907] write_pipe_buf+0x6a/0x90
[ 7009.873908] ? wakeup_pipe_readers+0x50/0x50
[ 7009.873909] __splice_from_pipe+0x8d/0x1a0
[ 7009.873911] ? _cond_resched+0x19/0x30
[ 7009.873912] ? wakeup_pipe_readers+0x50/0x50
[ 7009.873914] splice_from_pipe+0x5f/0x90
[ 7009.873915] default_file_splice_write+0x19/0x24
[ 7009.873917] do_splice+0x23f/0x640
[ 7009.873918] ? __do_sys_newfstat+0x61/0x70
[ 7009.873920] __x64_sys_splice+0x131/0x150
[ 7009.873923] do_syscall_64+0x5a/0x130
[ 7009.873925] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 7009.873926] RIP: 0033:0x7ff6c4ec4883
[ 7009.873931] Code: Bad RIP value.
[ 7009.873932] RSP: 002b:00007ff6ba7fb440 EFLAGS: 00000293 ORIG_RAX: 0000000000000113
[ 7009.873933] RAX: ffffffffffffffda RBX: 0000000000100000 RCX: 00007ff6c4ec4883
[ 7009.873934] RDX: 000000000000002a RSI: 0000000000000000 RDI: 000000000000002b
[ 7009.873935] RBP: 0000000000000000 R08: 0000000000100000 R09: 0000000000000004
[ 7009.873935] R10: 00007ff6ba7fb580 R11: 0000000000000293 R12: 000000000000002a
[ 7009.873936] R13: 0000000000000000 R14: 000000000000002b R15: 00007ff6ba7fb590
