Here is the current layout of the pool status. I caused this situation by force offline the drive and then removing it from the system to see if I could import the pool without it. Before doing it verified the drive only had around 5MB of metadata which I believed would not cause any issues minus some data loss. After the drive faulted the pool has been unable to import. When import read only all the data is not missing from the pool. I still have the drive with the metadata. The issue is that I canât clear the faulted issue without importing the drive with write access but that is not available. All of the other metadata is on the mirror vdevs and the data is under the main nas1 dataset.
I was wondering if there was anything I could do to just read the data from the drives or have the pool recognize the drive that it shows as external device fault. Iâve spent a few hours trying to learn more about zfs as I obviously did not know enough. I got the pool import in read only mode which is below but thats as far as I got.
Any help would be appreciated.
pool: nas1
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Replace the faulted device, or use âzpool clearâ to mark the device
repaired.
scan: resilvered 10.8M in 00:00:18 with 0 errors on Sat Jul 20 20:57:40 2024
config:
NAME STATE READ WRITE CKSUM
nas1 DEGRADED 0 0 0
raidz2-0 ONLINE 0 0 0
sdh2 ONLINE 0 0 0
sdk2 ONLINE 0 0 0
sdm2 ONLINE 0 0 0
sdi2 ONLINE 0 0 0
sdl2 ONLINE 0 0 0
sdg2 ONLINE 0 0 0
sda2 ONLINE 0 0 0
sdj2 ONLINE 0 0 0
special
mirror-1 ONLINE 0 0 0
nvme2n1p1 ONLINE 0 0 0
nvme3n1p1 ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
3d38b9ee-d2f1-11ed-8992-90e2ba3a4f1b ONLINE 0 0 0
3d378717-d2f1-11ed-8992-90e2ba3a4f1b ONLINE 0 0 0
ff14c02b-6b27-471a-a6ab-4e7bd904ccc7 FAULTED 0 0 0 external device fault
