I want to ask any zenfone 2 user in the tek community, have you ever had problems with the touchscreen of your phone?
My girlfriend wanted a phone that is cheap and good and I recommended her the zenfone 2(she got the 2gb quad core 1.8GHz version) and it suddenly went haywire after 3 weeks of having it(no dropping/used gorilla glass screen protector and a case that was pretty strong)
It just refuses to work on the upper portion and just works on some areas on the other 80% of the screen.
Normally I would just say just RMA it and they will fix it but after a quick google search I found out that MANY users had massive problems with the touch screen and even after RMA-ing it after some time the problem occurred again.
I get having some problems with the manufacturing process and some phones would suffer but it seems so frequent...
I really had faith in ASUS...but if you "repair" someone's phone and have it break a second and third time the same way sounds insane
Here is a link to one of their site where apparently hundreds of users have the same problem.
http://www.asus.com/zentalk/search.php?mod=forum&searchid=6&orderby=lastpost&ascdesc=desc&searchsubmit=yes&kw=touch
