Hello people have an issue my Coins don’t show up in my Jaxx Wallet? On Flypool it says 0.19 Zcash but its been 48hrs still hasn’t shown up in my wallet? I pasted in the Public address generated by Jaxx (Zcash address) it does mine but no Coins show up in Jaxx? I tried generatin Private keys and pasting them into the Batch file but Miner will not run it will only run when the Public address is pasted into the Batch file.
I wanted to invest in 12x GTX1070’s to mine Zcash so I decided to test with my 1080ti on my primary system Coins will not show up in my Jaxx Wallet even though Flypool says I have 0.19 Zcash? Please help.
Thanks for the response any help is much much appreciated can’t find any real help anywhere:( Yep its set to 0.001 in all Crypto currencies attached to my Wallet.
Do I paste the Public address generated in my Jaxx Wallet? That’s what I did and it started mining but its not showing up in my Wallet? I tried generating private keys and pasting them into the Batch file but Miner won’t run so I assume I did it correctly in the first place? I’ve been building systems for 20 years but this has really pickled my noodle.
I had my finger on the trigger to order 12x 1070’s today but I can’t get this one working hahahaha! Not sure where I’ve gone wrong? Youtubers are no help they make these bloody videos then won’t answer questions I always answer every question if someone is in trouble on my Channel.
Oh yea Flypool says 0.19 Zcash Unpaid whatever that means any idea?
well… maybe try to setup a different zcash wallet. from my experience those all in one fancy ui wallets where everything is online and in a brwoser… i dont trust them. maybe thats just paranoia but i cant help it. set up a basic zcash wallet and let the coins transfer to it.
Yeah, there are a lot of videos that make it seem like it only takes 15min of effort to get going. But it seems like there are an awful lot of little things anyone interested should know.
Definitely your public key, private key is for making payments.
If it says unpaid that should mean they haven’t sent your reward yet. So the good news is nothing has gone wrong with the mining, the bad news is that you don’t know why they’ve not paid out. I’ve read elsewhere that smaller amounts get less priority on pools. You could be waiting a while, 48 hours sounds like a lot but it might be normal?
Because of performance issues with the Zcash client we are unable to send payout transactions to z addresses! Therefore DO NOT use z addresses to mine on the pool.
I don’t know what this means but maybe it is your answer?
That’s what I’m using now pasted the Zcash4win Public Address into the Batch File it started mining according to flypool but now I lost my 0,19 Zcash from the other Public address? No Zcash has shown up in Zcash4win either.
Zcash transparent addresses, aka T-addrs, are very similar to Bitcoin addresses. Zcash also provides Z-addrs which are used for sending and receiving private funds, with transactions cryptographically protected with Zero-Knowledge proofs. T-addrs all begin with a t… prefix whereas Z-addrs always begin with a z… prefix.
I would think the problem now is that you have pending funds on a wallet type they won’t payout to. Their twitter feed seems to indicate that they have cleared other backlogs in recent days, but seems like you might be able to transfer the funds from one wallet to another?
i dont know shit about zcash and how their wallets work. you mine zcash so: how do the wallets work?! first things first is read a lot before starting things.
