So, because of the great deal on the i7 3770k, i've decided to go intel. I don't have that much money to spend on the mobo, and i don't know the best brands by any means. All that it needs is a RAM speed of at least 1600, 1 pci 2.0 x16 slot (gtx matrix 580), and that's about it. Anything less than $100 is ok. Thanks in advance!
EDIT: so i found theZ77 Pro4 LGA 1155 ATX Intel Motherboard for $110 (a little over budget). Is that mobo good for the money? are there others that are better?
