Hey quick question that I can’t seem to find a clear answer -
On the new z690 motherboards with pci 5.0 that has the 1x16 pci 5.0 or 2x8 pci 5.0 config, if putting say a rtx 3090 in a slot and a 4x pci 4.0 p5800x drive on an adapter board in the other, would they report and run at pci 4.0 16x and 4x respectively?
If the device committing to a pcie address identifies as another generation, the controller will take that channel / connection and make it run at that generation’s speeds.
So, if you have a X16 slot for a GPU, a X16 slot with a X4 SSD in it, and maybe a wifi card in a X4 that is a X1, the GPU will have the full 16 of its generation, the SSD the same, the wifi card the same.
They will not magically run at 5 speeds because the devices themselves do not have a PCIe 5.0 related controller, though might ID as 4.1 or 4.2 due to from factory speed upgrades or other random crap.
Thanks for the reply that helps, but I guess overall I’m wondering … so now currently with the z590 board the 3090 is at 8x, and the p5800x is at its normal 4x speed in the other 16x slot. So with this new gen z690, with the same 2 pci slots being populated, would the 3090 run at 16x and the p5800x 4x, or would it just default to 8x/4x ?
