Z170 pro gaming arua lentency problems
Hej been a long time fan of teksyndicat oh i mean Levelonetech :smiley:.
I have spent countless hours trying to fix this problem with my pc.
But after countless reinstalls, bios update and all that googling can offer i desided to try my luck here.
If there is any info you may need to help me just ask and i will previd I am happy to help you help me :rofl:
TLDR: Random Lag and stutter witch follows me from win 10 to win 7 to win 8.1 to win 10 again.
Notist that client server runtime process uses 75 to 90 persent of the gpu
So to get down to business.
Specs:
MB: Z170 pro gaming arua Bios Version=3610
Grafic Card: asus radeon rx 480 strix gaming 8gb
Ram: 16 GB corsair DDR4 (2x8GB) CMU16GX4M2C3000C15
CPU: Intel i5-6600k 3.50GHz
HDD: 4000 GB WD
SDD: 2 ssd in RAID 0
PSU: Corsair AX860
OS: Windows 10 Pro 64 bit
Case: Thermaltake core p5
Keyborad: Corsair K75 RGB.
Muse: steelseries rival 300.
Headset: Arctis 7
Now to the problem i have been having.
So it all started some months ago this was not the first time i have the pc up and running it had bean alive at lest a year or so befor pc hell came to visit, The pc was running normaly with the same specs no changes to hardware, but it was getting time for a reinstall of windows, i do it like once every 1-2 years when it starts getting slow. i was no windows 10 then to but was getting tired of it changing my setting and stuff every bloody update. So i whent back to windows 7 pro 64 bit
. Had a hell of a time getting all the drives since i had no usb port drivers or internet drives so i was hard to get it working but in the end it was but then i notised sound lag/dropouts, and just general lag and stutter, tryed reinstalling win7 no help then win 8.1 no help then win 10 again and still same problem so it was following me from reinstall to reinstall so my mind was on hardware problem. Then i found LatencyMon of witch i have posted
Of witch i found Wdf01000.sys looked like it was the culprit but after endless googling no help was found.
Even after a clean instals and only windows updates done it still there hiding some where(bloody pc gremlins).
Its not all ways lags but it comes and goes sometime its more powerfull lag making pc useless sometimes only sound lag.
I made a little video cuz its easyer to see it the read all this :smiley: but of course the problem did not show its ugly head will update when i get the bastarder on video. HAHA got it https://youtu.be/00-FWZvD_hs for me the sound is more like statick interferisons on the video it just seam to cut but u get the point, can see me dragging the chrome window and it lagging whole pc is like this then as so as i start latencyMon it goes back to normal so werid.
Wat i have tryed:
Windows 7,8.1,10.
All the drivers asus had to offer on all of the above OS.
Bios update to 3610
Virus scans found some but none left now hihi.
Deleted my raid and redid it when i did the last win 10 install i am on now.
with and with out AMD radeons Relive.
With and with out corsairs and aruas Led programs/drivers.
And all to no help.
I am ok at fixing pc problem but this f**ker has taken me for a good long ride, ITS TIME TO STOP :stuck_out_tongue: .
Info from latencyMon
SYSTEM INFORMATION
Computer name: DESKTOP-P2NL0BA
OS version: Windows 10 , 10.0, build: 17134 (x64)
Hardware: ASUSTeK COMPUTER INC., Z170 PRO GAMING/AURA
CPU: GenuineIntel Intel(R) Coreâ„¢ i5-6600K CPU @ 3.50GHz
Logical processors: 4
Processor groups: 1
RAM: 16324 MB total
CPU SPEED
Reported CPU speed: 3504 MHz
Measured CPU speed: 1 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 22078.207863
Average measured interrupt to process latency (µs): 5.746470
Highest measured interrupt to DPC latency (µs): 20052.713698
Average measured interrupt to DPC latency (µs): 3.279436
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 5014.343607
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.012082
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.012082
ISR count (execution time <250 µs): 402627
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 1
ISR count (execution time 1000-1999 µs): 7
ISR count (execution time 2000-3999 µs): 11
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 24167.513128
Driver with highest DPC routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%): 0.472678
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 0.812440
DPC count (execution time <250 µs): 5539715
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 1759
DPC count (execution time 1000-1999 µs): 4053
DPC count (execution time 2000-3999 µs): 4991
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Highest hard pagefault resolution time (µs): 0.0
Total time spent in hard pagefaults (%): 0.0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 95.310198
CPU 0 ISR highest execution time (µs): 5014.343607
CPU 0 ISR total execution time (s): 0.548637
CPU 0 ISR count: 340748
CPU 0 DPC highest execution time (µs): 24167.513128
CPU 0 DPC total execution time (s): 29.496534
CPU 0 DPC count: 4771305
CPU 1 Interrupt cycle time (s): 57.999781
CPU 1 ISR highest execution time (µs): 4037.565639
CPU 1 ISR total execution time (s): 0.099854
CPU 1 ISR count: 59904
CPU 1 DPC highest execution time (µs): 20107.795091
CPU 1 DPC total execution time (s): 12.413206
CPU 1 DPC count: 552840
CPU 2 Interrupt cycle time (s): 41.708599
CPU 2 ISR highest execution time (µs): 29.880137
CPU 2 ISR total execution time (s): 0.002972
CPU 2 ISR count: 1997
CPU 2 DPC highest execution time (µs): 16107.085616
CPU 2 DPC total execution time (s): 1.580539
CPU 2 DPC count: 174697
CPU 3 Interrupt cycle time (s): 42.025692
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 6010.056507
CPU 3 DPC total execution time (s): 0.317025
CPU 3 DPC count: 53103
