when trying to install or update with yum i get the error "Another app is currently holding the yum lock"
That means another program is using yum, probably the software updater program. it should give you a id number in () that is the process that is holding yum, you can kill that number if you like.
so say that it says
error: Another app is currently holding the yum lock (1234)
you can do "kill 1234"
then you can do your yum command again.
