Hello! I recently based a build for a friend off of your video on youtube "Build a workstation PC- Our Dual Xeon Build", Basically the Motherboard and the Case. After receiving all the parts and after getting started with the build i noticed the motherboard didn't fit. I looked closely at the video and noticed the case in the video was larger then the case i had and that was linked and described in the video. I think the case used in the video is the Fractal Define XL R2 NOT the Fractal Define R4. Now i am stuck with a case that doesn't fit the motherboard. This needs to be corrected on the youtube video because i don't want this mis information to lead other people buy this combination of case and motherboard and be put in the situation that i currently am in. If you have an suggestions or incite into what could be done, I'd appreciate it very much.
No the case is definitely the Define R4. I have worked in it and can recognize it from just about any angle. In the video they touch on the motherboard in the case at the 9:58 mark. You may have to some tinkering to get it to fit in.
Its not a define r4. Look at the top drive bay. It looks exactly like the XL R2. Plus my issue doesnt have to do with standoffs not lining up, The last 2 RAM slots would be installed underneath the top drive bay caddie making them completely unusable.
try to contact fractal. fractal is a good company and i think they wanna help you with this. and i think you may need to pay 30$ more for the xl r2. other thing you can do is contact the vender. they may take it back if you buy something else for the same price or higher. good luck!
I'm a bit confused myself. In the video he says it will be just fine in the define R4 but in the Blog post here https://teksyndicate.com/videos/build-workstation-pc-our-dual-xeon-build-and-guidelines-help-yours?page=1. It says for big motherboard go with the XL R2. As a last resort, try installing without any of the Drive bays, and see if you can still put them in when the motherboard is in. If not, try to contact Fractal Design or wherever you got it from for a refund to get a bigger case.
I will have to contact fractal or the distributor. There is no way this going going to fit. I just want the youtube video fixed so now one else gets screwed like I am.
