Your nvidia "manage 3D settings"
i was wondering what everyone's settings were
i'm not too sure what mine should be set to, i dun understand what everything in it does/is.
here's a template you can use to copy/paste and put in the info in
Anisotropic Filtering =
Anisotropic - gamma correction =
Antialiasing - Mode =
Antialiasing - Setting =
Antialiasing - Transparency =
Conformant texture clamp =
Error reporting =
Extension limit =
Force mipmaps =
Maximum pre-rendered frames =
Multi-display/mixed-GPU acceleration =
SLI performance mode =
Texture filtering - Anisotropic sample optimization =
Texture filtering - Negative LOD bias =
Texture filtering - Quality =
Texture filtering - Trilinear optimization =
Threaded optimization =
Triple buffering =
Vertical sync =
Im just using defaults.
Like, everything is controlled in the actual game.
You do see a differece when you put everything to the higher quality. try running crysis with them on high. that's the ultimate test.
I just in game settings. I have seen confliction when trying to use nVidia's controll panel then messsing with settings in game. Id much rather use the games rendering
oh ok thx, i thought it just overrided anything, that would explain why i was having such a problem with grid
so is everybody else using game settings as well?
Maxing out the nVidia settings cuts my FPS in half, versus using the games max settings, but I didn't notice a difference in picture quality...
