Recently i came across the Yolobox pro device, which is an easy stream management device when you can add sources, overlays and all, within one device. It turns out that it runs android, a none standard version of it that is.
I am trying to see if someone has an idea about it and if there is some effort to port that Os to standard smartphones or other small devices.
