A socket AM3 CPU clocked at 3Ghz and it's pretty cheap
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
Wow...Ill be getting that soon.
>AMD nthx.
[url=http://www.newegg.com/Product/Productcompare.aspx?Submit=Property&N=2010340343&PropertyCodeValue=507%3A44915%2C507%3A46347&bop=And&CompareItemList=N82E16819103674%2CN82E16819115202]Comparison[/url]
It's about 35 bucks less, it's 600Mhz. faster, the motherboards are cheaper/don't suck as much for the money, and it's a higher number so Bauer [b]might[/b] be getting it.
But are [u]you[/u] honest to god getting this?
Sadly I don't have the money :(
Yes I know that is for nate
No offense to you at all, but you're always window shoppin' nahmean?
Yeah I has no life [img]http://www.allemoticons.com/Sad/Sad_1009.gif[/img]
the i7 is better, it can do triple channel ddr3 while the AMD's cant even do ddr3, as far as i know all C2D up to i7's can do ddr3 as long as the motherboard can, and as far as i know no AMD's can do ddr3 because of the crappy cpu
so i7 > Phenom
