I have been messing around with Adobe Air for the past few days and let me tell you guys... IT IS AWESOME links will be posted at the end. I have applications running such as Snakr (a news feed that runs at the bottom of your screen horizontally) as well as a program called DestroyTwitter. I dont even go to Twitter.com as I only use the application now. Everyone should look into using Adobe Air as it is a very light weight and free applicationPeace and happy gaming,AnoxiAhttp://www.adobe.com/products/air/http://snackr.net/https://destroytwitter.com/
Yep Yep, It's good, but mostly dumb applications you would find on an iphone
What's Adobe Air do?
It allows you to install a bunch of mini-application type files designed for use with Adobe Air.
