Currently tourbleshooting my XPS 13. It started with display port dongles and ethernet not working. Both of the thunderbolt and USB C kind. All confirmed working dongles. Dual booting windows and fedora. Both would fail simultaniously for the same things. Before that I already had trouble booting the notebook ocassionally and there was one instance where it just kept beeping. Now the lights on the keyboard blink when plugging in power and I can´t seem to be able to turn it on again at all.
I came across this dell post that suggested to remove the CMOS battery for 30 minutes. Which is whats happing now CMOS battery is on the floor well see in 30 minutes. I also found some post from HP here that mentions a bunch of potential issues when the CMOS battery is indeed dead.
The laptop has difficult booting up - Yes
There’s a constant beeping noise from the motherboard - Not permanently, but has happened and could not make it stop other then… waiting for tomorrow and then it was gone
The date and time have reset - Can´t confirm or deny, probably would not notice when the internet is connected basically always
Peripherals aren’t responsive or they don’t respond correctly - Yes
Hardware drivers have disappeared - Maybe, not sure
You can’t connect to the internet - Sort of WIFI still worked, but ethernet dogles where all dead
So. I checked almost every single one of those things. Can a dead CMOS battery really cause any of this? Seems so obscure. Or is it just a dead mainboard without professional repair? Which at this point seems like the more logical conclusion to me than ordering a CMOS battery.
Well… the half an hour is about over, put it back together, changed nothing. Gonna dd the drive clean and find somebody who can possibly repair it.
I would expect it to just be about system clock and bios settings. The clock being wrong can cause some issues. I can see how it can prevent booting in a sence that resetting the bios can turn back on secure boot and grub may not boot (but windows should work directly). Not sure atm if Fedora is graced by Microsoft in that sence.
Not turning on at all seems silly. I did invest into a new battery very recently. Because the old one had like literally 5 minutes of juice and I expected that to sort of fix my occasional troubles to boot the machine. But back then this wasn’t a permanent state, but rather you just had to sit and wait for half a minute and then it would start working again.
I did put the drive into my desktop to overwride with random data, because I did have some work stuff on there. Like SSH keys and it’s not encrypted. Gonna put it back in and find somebody who can have a look at it next week.
Im more of a software guy with hardware issues like that Im pretty helpless tbh. The board looks perfectly fine nothing looks burnt, no liquid damage, no corrosion. The power button definitely does something, because the battery indicator lights up when pressing it on the other end of the board. The battery is fully charged assuming the battery indicator still works. But other than lights when you press the power button or plug it into the wall there is no sign of life right now. No fan spin. No nothing. The battery indicator light is also no sign of life. The XPS notebooks have 5 leds and a button next to it, which you can press even when the system is off to check how much battery you have. I never noticed that it also lights up when pressing the power button before.
