ok, so after I install XP, to dual boot with Vista 64 bit, it installs to the HDD fine and all, reboot to go to GUI install, BAM nothing, it goes through post, then to where it says press .. key to boot to cd, I press nothing so it will go ahead to boot from HDD, and it does nothing, I get wierd freaky symbols on my screen...
I am lead to think it is a BIOS problem or something, because the only thing I have changed in the past 6 months, winch was a month ago was getting a new mobo and CPU,
Vista installs and works great, but I cannot dual boot with XP, I have XP home, pro, pro corp, and pro 64 bit, none work.......
Why is it doing this, I reinstalled the Vista boot loader so I could use my OS again, but I cannot get XP past the text mode and reboot phase, I NEVER get to the GUI install mode... the disk work on other things, computers, virtual PC, just not to dual boot, but then again, I have never tried single booting XP oin this board either....
AMD Athlon 64 X2 4200+ ~ 2.7 GHZ stable
GIGABYTE MA780G-UDH3
6 GB ram, 4 GB OCZ SLI, 2 GB kingston, all 800 MHz
1 TB Seagate Baracuda
Lite-on IDE DVD-+RW
PNY nVidia GeForce 9800GT
thats my specs, I had all of the same hardware before, but running on a nForce 630i with a Core 2 Duo E4500, and I didnt dual boot, but I could rum XP fine on it...
