I’m daily-driving OpenSUSE 15.3 machine and occasionally I’m launching Windows VM with GPU passthrough. I have two GPUs - GTX 1050 for linux desktop and GTX1070Ti for Windows. To make it work I had to put 1070 in second PCI-e slot, so that UEFI can use 1050 as main card. Everything was working fine, but that setup is not ideal, since my second and third PCI-e slots are in 1 slot distance, which means that if I put anything in third slot, my Windows GPU (dedicated for gaming) will have little to no room for air intake.
So I decided to try swapping GPU slots and passing GPU from first slot to VM. To do that I’ve added video=efifb:off,vesafb:off kernel parameter and added file to xorg.conf.d with Device section and BusID specified. But apparently I didn’t even get to VM part, since my Xorg stopped launching. What I found so far is that if I disconnect monitor attached to GPU in first slot, everything works just fine. I tried removing video=efifb:off,vesafb:off flag, but it didn’t change anything.
Here is dmesg from not working system:
[ 0.000000] Linux version 5.19.8-lp153.3.g14c495f-default (geeko@buildhost) (gcc (SUSE Linux) 11.3.0, GNU ld (GNU Binutils; SUSE Linux Enterprise 15) 2.37.20211103-150100.7.37) #1 SMP PREEMPT_DYNAMIC Tue Sep 13 05:14:37 UTC 2022 (14c495f)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.19.8-lp153.3.g14c495f-default root=UUID=7c57285f-d536-4bf2-9c06-87dddeb221f7 default_hugepagesz=1G hugepagesz=1G hugepages=12 iommu=pt video=efifb:off,vesafb:off amd_iommu=on rd.driver.pre=vfio-pci mitigations=auto
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 3376
[redacted]
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0xaa622000 ACPI 2.0=0xaa622014 TPMFinalLog=0xaa94e000 SMBIOS=0xab7e8000 SMBIOS 3.0=0xab7e7000 MEMATTR=0xa6546018 ESRT=0xa685cd18 MOKvar=0xa6549000 RNG=0xab82df18 TPMEventLog=0x9faf7018
[ 0.000000] efi: seeding entropy pool
[ 0.000000] random: crng init done
[ 0.000000] SMBIOS 3.3.0 present.
[ 0.000000] DMI: ASUS System Product Name/ProArt X570-CREATOR WIFI, BIOS 0801 04/26/2022
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] last_pfn = 0x84f300 max_arch_pfn = 0x400000000
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] e820: update [mem 0xaa6e0000-0xaa6effff] usable ==> reserved
[ 0.000000] e820: update [mem 0xb0000000-0xffffffff] usable ==> reserved
[ 0.000000] last_pfn = 0xad000 max_arch_pfn = 0x400000000
[ 0.000000] esrt: Reserving ESRT space from 0x00000000a685cd18 to 0x00000000a685cd50.
[ 0.000000] e820: update [mem 0xa685c000-0xa685cfff] usable ==> reserved
[ 0.000000] e820: update [mem 0xa6549000-0xa6549fff] usable ==> reserved
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] Secure boot disabled
[redacted]
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000084f2fffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x84f2d5000-0x84f2fffff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000084f2fffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x0000000009d1efff]
[ 0.000000] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.000000] node 0: [mem 0x000000000a20e000-0x00000000a3102fff]
[ 0.000000] node 0: [mem 0x00000000a3104000-0x00000000a9ef1fff]
[ 0.000000] node 0: [mem 0x00000000ab9ff000-0x00000000acffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000084f2fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000084f2fffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 737 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 14 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 1 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 6925 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 3328 pages in unavailable ranges
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] e820: update [mem 0xa43a7000-0xa4557fff] usable ==> reserved
[ 0.000000] smpboot: Allowing 32 CPUs, 0 hotplug CPUs
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[redacted]
[ 0.000000] [mem 0xb0000000-0xefffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:1
[ 0.000000] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[ 0.000000] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.000000] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8234350
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19.8-lp153.3.g14c495f-default root=UUID=7c57285f-d536-4bf2-9c06-87dddeb221f7 default_hugepagesz=1G hugepagesz=1G hugepages=12 iommu=pt video=efifb:off,vesafb:off amd_iommu=on rd.driver.pre=vfio-pci mitigations=auto
[ 0.000000] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.19.8-lp153.3.g14c495f-default", will be passed to user space.
[ 0.000000] printk: log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] printk: log_buf_len total cpu_extra contributions: 1015808 bytes
[ 0.000000] printk: log_buf_len min size: 262144 bytes
[ 0.000000] printk: log_buf_len: 2097152 bytes
[ 0.000000] printk: early log buf free: 242472(92%)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 2661428K/33460872K available (14343K kernel code, 2917K rwdata, 7380K rodata, 2924K init, 6072K bss, 13488556K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.000000] ftrace: allocating 44314 entries in 174 pages
[ 0.000000] ftrace: allocated 174 pages with 5 groups
[ 0.000000] Dynamic Preempt: voluntary
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=32.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.000000] NR_IRQS: 524544, nr_irqs: 1224, preallocated irqs: 16
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] printk: console [tty0] enabled
[ 0.000000] ACPI: Core revision 20220331
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.000000] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.004000] Switched APIC routing to physical flat.
[ 0.004000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.028000] tsc: PIT calibration matches HPET. 1 loops
[ 0.028000] tsc: Detected 3400.039 MHz processor
[ 0.000001] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3102731c084, max_idle_ns: 440795218402 ns
[ 0.000006] Calibrating delay loop (skipped), value calculated using timer frequency.. 6800.07 BogoMIPS (lpj=13600156)
[ 0.000008] pid_max: default: 32768 minimum: 301
[ 0.001908] LSM: Security Framework initializing
[ 0.001925] AppArmor: AppArmor initialized
[ 0.001968] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.004020] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.004267] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.004301] LVT offset 1 assigned for vector 0xf9
[ 0.004423] LVT offset 2 assigned for vector 0xf4
[ 0.004454] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.004455] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.004458] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.004460] Spectre V2 : Mitigation: Retpolines
[ 0.004462] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.004463] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.004464] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.004466] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.004468] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.004470] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.014066] Freeing SMP alternatives memory: 36K
[ 0.124411] smpboot: CPU0: AMD Ryzen 9 5950X 16-Core Processor (family: 0x19, model: 0x21, stepping: 0x0)
[ 0.124472] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.124475] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.124484] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.124491] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.124497] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.124500] ... version: 0
[ 0.124501] ... bit width: 48
[ 0.124502] ... generic registers: 6
[ 0.124503] ... value mask: 0000ffffffffffff
[ 0.124504] ... max period: 00007fffffffffff
[ 0.124505] ... fixed-purpose events: 0
[ 0.124506] ... event mask: 000000000000003f
[ 0.124542] rcu: Hierarchical SRCU implementation.
[ 0.124543] rcu: Max phase no-delay instances is 1000.
[ 0.124765] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.124889] smp: Bringing up secondary CPUs ...
[ 0.124930] x86: Booting SMP configuration:
[ 0.124932] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16
[ 0.160057] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.160071] #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
[ 0.192021] smp: Brought up 1 node, 32 CPUs
[ 0.192024] smpboot: Max logical packages: 1
[ 0.192025] smpboot: Total of 32 processors activated (217602.49 BogoMIPS)
[ 0.208876] node 0 deferred pages initialised in 16ms
[ 0.208876] devtmpfs: initialized
[ 0.208876] x86/mm: Memory block size: 128MB
[ 0.212191] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
[ 0.212191] ACPI: PM: Registering ACPI NVS region [mem 0xaa623000-0xaa99afff] (3637248 bytes)
[ 0.212191] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.212191] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.212191] pinctrl core: initialized pinctrl subsystem
[ 0.212223] PM: RTC time: 00:41:55, date: 2022-11-15
[ 0.212333] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.212385] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.212392] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.212397] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.212401] audit: initializing netlink subsys (disabled)
[ 0.212405] audit: type=2000 audit(1668472915.240:1): state=initialized audit_enabled=0 res=1
[ 0.212405] thermal_sys: Registered thermal governor 'fair_share'
[ 0.212405] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.212405] thermal_sys: Registered thermal governor 'step_wise'
[ 0.212405] thermal_sys: Registered thermal governor 'user_space'
[ 0.212405] cpuidle: using governor ladder
[ 0.212405] cpuidle: using governor menu
[ 0.212405] Detected 1 PCC Subspaces
[ 0.212405] Registering PCC driver as Mailbox controller
[ 0.212405] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.212405] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.212405] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.212405] PCI: Using configuration type 1 for base access
[ 0.212910] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.212915] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.225621] HugeTLB registered 1.00 GiB page size, pre-allocated 12 pages
[ 0.225624] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.225640] ACPI: Added _OSI(Module Device)
[ 0.225640] ACPI: Added _OSI(Processor Device)
[ 0.225640] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.225640] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.225640] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.225640] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.225640] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.236661] ACPI: 10 ACPI AML tables successfully acquired and loaded
[ 0.237811] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.239889] ACPI: EC: EC started
[ 0.239891] ACPI: EC: interrupt blocked
[ 0.239931] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.239933] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 0.239935] ACPI: Interpreter enabled
[ 0.239944] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.239945] ACPI: Using IOAPIC for interrupt routing
[ 0.240198] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.240200] PCI: Using E820 reservations for host bridge windows
[ 0.240465] ACPI: Enabled 3 GPEs in block 00 to 1F
[ 0.244234] ACPI: PM: Power Resource [BTRT]
[ 0.247921] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.247926] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.247993] acpi PNP0A08:00: _OSC: platform does not support [LTR DPC]
[ 0.248115] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability]
[ 0.248123] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 0.248348] PCI host bridge to bus 0000:00
[ 0.248349] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.248352] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.248353] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.248354] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.248356] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.248357] pci_bus 0000:00: root bus resource [mem 0xb0000000-0xefffffff window]
[ 0.248358] pci_bus 0000:00: root bus resource [mem 0x850000000-0x7fffffffff window]
[ 0.248360] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.248373] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[ 0.248461] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600
[ 0.248559] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[ 0.248618] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
[ 0.248653] pci 0000:00:01.1: enabling Extended Tags
[ 0.248715] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.248812] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400
[ 0.248847] pci 0000:00:01.2: enabling Extended Tags
[ 0.248908] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.249008] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[ 0.249072] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[ 0.249131] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
[ 0.249232] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 0.249586] pci 0000:00:03.2: [1022:1483] type 01 class 0x060400
[ 0.249689] pci 0000:00:03.2: PME# supported from D0 D3hot D3cold
[ 0.249792] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[ 0.249857] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[ 0.249922] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[ 0.249979] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[ 0.250015] pci 0000:00:07.1: enabling Extended Tags
[ 0.250072] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.250162] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[ 0.250220] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[ 0.250257] pci 0000:00:08.1: enabling Extended Tags
[ 0.250319] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.250430] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.250549] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.250671] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
[ 0.250689] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
[ 0.250707] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
[ 0.250726] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
[ 0.250744] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
[ 0.250761] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
[ 0.250779] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
[ 0.250797] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
[ 0.250872] pci 0000:01:00.0: [144d:a809] type 00 class 0x010802
[ 0.250896] pci 0000:01:00.0: reg 0x10: [mem 0xec500000-0xec503fff 64bit]
[ 0.251140] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.251146] pci 0000:00:01.1: bridge window [mem 0xec500000-0xec5fffff]
[ 0.251205] pci 0000:02:00.0: [1022:57ad] type 01 class 0x060400
[ 0.251273] pci 0000:02:00.0: enabling Extended Tags
[ 0.251373] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.251486] pci 0000:02:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 126.024 Gb/s with 16.0 GT/s PCIe x8 link)
[ 0.251541] pci 0000:00:01.2: PCI bridge to [bus 02-3e]
[ 0.251547] pci 0000:00:01.2: bridge window [mem 0xb8000000-0xe81fffff]
[ 0.251551] pci 0000:00:01.2: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.251759] pci 0000:03:00.0: [1022:57a3] type 01 class 0x060400
[ 0.251843] pci 0000:03:00.0: enabling Extended Tags
[ 0.252100] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.252471] pci 0000:03:02.0: [1022:57a3] type 01 class 0x060400
[ 0.252554] pci 0000:03:02.0: enabling Extended Tags
[ 0.252810] pci 0000:03:02.0: PME# supported from D0 D3hot D3cold
[ 0.253148] pci 0000:03:03.0: [1022:57a3] type 01 class 0x060400
[ 0.253231] pci 0000:03:03.0: enabling Extended Tags
[ 0.253500] pci 0000:03:03.0: PME# supported from D0 D3hot D3cold
[ 0.253837] pci 0000:03:04.0: [1022:57a3] type 01 class 0x060400
[ 0.253921] pci 0000:03:04.0: enabling Extended Tags
[ 0.254176] pci 0000:03:04.0: PME# supported from D0 D3hot D3cold
[ 0.254534] pci 0000:03:05.0: [1022:57a3] type 01 class 0x060400
[ 0.254618] pci 0000:03:05.0: enabling Extended Tags
[ 0.254873] pci 0000:03:05.0: PME# supported from D0 D3hot D3cold
[ 0.255234] pci 0000:03:08.0: [1022:57a4] type 01 class 0x060400
[ 0.255336] pci 0000:03:08.0: enabling Extended Tags
[ 0.255512] pci 0000:03:08.0: PME# supported from D0 D3hot D3cold
[ 0.255715] pci 0000:03:09.0: [1022:57a4] type 01 class 0x060400
[ 0.255799] pci 0000:03:09.0: enabling Extended Tags
[ 0.255974] pci 0000:03:09.0: PME# supported from D0 D3hot D3cold
[ 0.256168] pci 0000:03:0a.0: [1022:57a4] type 01 class 0x060400
[ 0.256251] pci 0000:03:0a.0: enabling Extended Tags
[ 0.256442] pci 0000:03:0a.0: PME# supported from D0 D3hot D3cold
[ 0.256648] pci 0000:02:00.0: PCI bridge to [bus 03-3e]
[ 0.256659] pci 0000:02:00.0: bridge window [mem 0xb8000000-0xe81fffff]
[ 0.256667] pci 0000:02:00.0: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.256776] pci 0000:04:00.0: [144d:a809] type 00 class 0x010802
[ 0.256811] pci 0000:04:00.0: reg 0x10: [mem 0xe8100000-0xe8103fff 64bit]
[ 0.257206] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.257217] pci 0000:03:00.0: bridge window [mem 0xe8100000-0xe81fffff]
[ 0.257375] pci 0000:05:00.0: [8086:1136] type 01 class 0x060400
[ 0.257466] pci 0000:05:00.0: enabling Extended Tags
[ 0.257646] pci 0000:05:00.0: supports D1 D2
[ 0.257647] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.257925] pci 0000:03:02.0: PCI bridge to [bus 05-38]
[ 0.257936] pci 0000:03:02.0: bridge window [mem 0xb8000000-0xe71fffff]
[ 0.257944] pci 0000:03:02.0: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.258063] pci 0000:06:00.0: [8086:1136] type 01 class 0x060400
[ 0.258158] pci 0000:06:00.0: enabling Extended Tags
[ 0.258334] pci 0000:06:00.0: supports D1 D2
[ 0.258335] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.258566] pci 0000:06:01.0: [8086:1136] type 01 class 0x060400
[ 0.258661] pci 0000:06:01.0: enabling Extended Tags
[ 0.258835] pci 0000:06:01.0: supports D1 D2
[ 0.258836] pci 0000:06:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.259057] pci 0000:06:02.0: [8086:1136] type 01 class 0x060400
[ 0.259152] pci 0000:06:02.0: enabling Extended Tags
[ 0.259316] pci 0000:06:02.0: supports D1 D2
[ 0.259317] pci 0000:06:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.259538] pci 0000:06:03.0: [8086:1136] type 01 class 0x060400
[ 0.259633] pci 0000:06:03.0: enabling Extended Tags
[ 0.259807] pci 0000:06:03.0: supports D1 D2
[ 0.259809] pci 0000:06:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.260050] pci 0000:05:00.0: PCI bridge to [bus 06-38]
[ 0.260064] pci 0000:05:00.0: bridge window [mem 0xb8000000-0xe71fffff]
[ 0.260073] pci 0000:05:00.0: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.260185] pci 0000:07:00.0: [8086:1137] type 00 class 0x0c0340
[ 0.260222] pci 0000:07:00.0: reg 0x10: [mem 0x7fb5100000-0x7fb513ffff 64bit pref]
[ 0.260245] pci 0000:07:00.0: reg 0x18: [mem 0x7fb5140000-0x7fb5140fff 64bit pref]
[ 0.260296] pci 0000:07:00.0: enabling Extended Tags
[ 0.260464] pci 0000:07:00.0: supports D1 D2
[ 0.260465] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.260684] pci 0000:06:00.0: PCI bridge to [bus 07]
[ 0.260698] pci 0000:06:00.0: bridge window [mem 0xe7100000-0xe71fffff]
[ 0.260708] pci 0000:06:00.0: bridge window [mem 0x7fb5100000-0x7fb51fffff 64bit pref]
[ 0.260772] pci 0000:06:01.0: PCI bridge to [bus 08-1f]
[ 0.260786] pci 0000:06:01.0: bridge window [mem 0xd0000000-0xe6efffff]
[ 0.260796] pci 0000:06:01.0: bridge window [mem 0x7f90000000-0x7fb4ffffff 64bit pref]
[ 0.260903] pci 0000:20:00.0: [8086:1138] type 00 class 0x0c0330
[ 0.260941] pci 0000:20:00.0: reg 0x10: [mem 0xe7000000-0xe700ffff 64bit]
[ 0.261035] pci 0000:20:00.0: enabling Extended Tags
[ 0.261148] pci 0000:20:00.0: PME# supported from D3hot D3cold
[ 0.261292] pci 0000:06:02.0: PCI bridge to [bus 20]
[ 0.261305] pci 0000:06:02.0: bridge window [mem 0xe7000000-0xe70fffff]
[ 0.261377] pci 0000:06:03.0: PCI bridge to [bus 21-38]
[ 0.261390] pci 0000:06:03.0: bridge window [mem 0xb8000000-0xceffffff]
[ 0.261400] pci 0000:06:03.0: bridge window [mem 0x7f60000000-0x7f84ffffff 64bit pref]
[ 0.261553] pci 0000:39:00.0: [1d6a:94c0] type 00 class 0x020000
[ 0.261585] pci 0000:39:00.0: reg 0x10: [mem 0xe7800000-0xe787ffff 64bit]
[ 0.261607] pci 0000:39:00.0: reg 0x18: [mem 0xe78a0000-0xe78a0fff 64bit]
[ 0.261628] pci 0000:39:00.0: reg 0x20: [mem 0xe7400000-0xe77fffff 64bit]
[ 0.261642] pci 0000:39:00.0: reg 0x30: [mem 0xe7880000-0xe789ffff pref]
[ 0.261654] pci 0000:39:00.0: enabling Extended Tags
[ 0.261801] pci 0000:39:00.0: supports D1 D2
[ 0.261802] pci 0000:39:00.0: PME# supported from D0 D1 D3hot D3cold
[ 0.262035] pci 0000:03:03.0: PCI bridge to [bus 39]
[ 0.262045] pci 0000:03:03.0: bridge window [mem 0xe7400000-0xe78fffff]
[ 0.262174] pci 0000:3a:00.0: [8086:2725] type 00 class 0x028000
[ 0.262210] pci 0000:3a:00.0: reg 0x10: [mem 0xe8000000-0xe8003fff 64bit]
[ 0.262401] pci 0000:3a:00.0: PME# supported from D0 D3hot D3cold
[ 0.262573] pci 0000:03:04.0: PCI bridge to [bus 3a]
[ 0.262584] pci 0000:03:04.0: bridge window [mem 0xe8000000-0xe80fffff]
[ 0.262714] pci 0000:3b:00.0: [8086:15f3] type 00 class 0x020000
[ 0.262743] pci 0000:3b:00.0: reg 0x10: [mem 0xe7c00000-0xe7cfffff]
[ 0.262789] pci 0000:3b:00.0: reg 0x1c: [mem 0xe7d00000-0xe7d03fff]
[ 0.262972] pci 0000:3b:00.0: PME# supported from D0 D3hot D3cold
[ 0.263156] pci 0000:03:05.0: PCI bridge to [bus 3b]
[ 0.263167] pci 0000:03:05.0: bridge window [mem 0xe7c00000-0xe7dfffff]
[ 0.263293] pci 0000:3c:00.0: [1022:1485] type 00 class 0x130000
[ 0.263374] pci 0000:3c:00.0: enabling Extended Tags
[ 0.263562] pci 0000:3c:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.263724] pci 0000:3c:00.1: [1022:149c] type 00 class 0x0c0330
[ 0.264005] pci 0000:3c:00.1: reg 0x10: [mem 0xe7b00000-0xe7bfffff 64bit]
[ 0.264767] pci 0000:3c:00.1: enabling Extended Tags
[ 0.265296] pci 0000:3c:00.1: PME# supported from D0 D3hot D3cold
[ 0.265603] pci 0000:3c:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.265634] pci 0000:3c:00.3: reg 0x10: [mem 0xe7a00000-0xe7afffff 64bit]
[ 0.265706] pci 0000:3c:00.3: enabling Extended Tags
[ 0.265793] pci 0000:3c:00.3: PME# supported from D0 D3hot D3cold
[ 0.265928] pci 0000:03:08.0: PCI bridge to [bus 3c]
[ 0.265939] pci 0000:03:08.0: bridge window [mem 0xe7a00000-0xe7bfffff]
[ 0.266046] pci 0000:3d:00.0: [1022:7901] type 00 class 0x010601
[ 0.266130] pci 0000:3d:00.0: reg 0x24: [mem 0xe7f00000-0xe7f007ff]
[ 0.266154] pci 0000:3d:00.0: enabling Extended Tags
[ 0.266269] pci 0000:3d:00.0: PME# supported from D3hot D3cold
[ 0.266364] pci 0000:3d:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.266418] pci 0000:03:09.0: PCI bridge to [bus 3d]
[ 0.266428] pci 0000:03:09.0: bridge window [mem 0xe7f00000-0xe7ffffff]
[ 0.266535] pci 0000:3e:00.0: [1022:7901] type 00 class 0x010601
[ 0.266620] pci 0000:3e:00.0: reg 0x24: [mem 0xe7e00000-0xe7e007ff]
[ 0.266643] pci 0000:3e:00.0: enabling Extended Tags
[ 0.266758] pci 0000:3e:00.0: PME# supported from D3hot D3cold
[ 0.266852] pci 0000:3e:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.266905] pci 0000:03:0a.0: PCI bridge to [bus 3e]
[ 0.266915] pci 0000:03:0a.0: bridge window [mem 0xe7e00000-0xe7efffff]
[ 0.267043] pci 0000:3f:00.0: [10de:1b82] type 00 class 0x030000
[ 0.267062] pci 0000:3f:00.0: reg 0x10: [mem 0xeb000000-0xebffffff]
[ 0.267078] pci 0000:3f:00.0: reg 0x14: [mem 0x7fe0000000-0x7fefffffff 64bit pref]
[ 0.267094] pci 0000:3f:00.0: reg 0x1c: [mem 0x7ff0000000-0x7ff1ffffff 64bit pref]
[ 0.267105] pci 0000:3f:00.0: reg 0x24: [io 0xf000-0xf07f]
[ 0.267116] pci 0000:3f:00.0: reg 0x30: [mem 0xec000000-0xec07ffff pref]
[ 0.267142] pci 0000:3f:00.0: BAR 1: assigned to efifb
[ 0.267282] pci 0000:3f:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x8 link at 0000:00:03.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.267328] pci 0000:3f:00.1: [10de:10f0] type 00 class 0x040300
[ 0.267345] pci 0000:3f:00.1: reg 0x10: [mem 0xec080000-0xec083fff]
[ 0.267527] pci 0000:00:03.1: PCI bridge to [bus 3f]
[ 0.267532] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.267534] pci 0000:00:03.1: bridge window [mem 0xeb000000-0xec0fffff]
[ 0.267539] pci 0000:00:03.1: bridge window [mem 0x7fe0000000-0x7ff1ffffff 64bit pref]
[ 0.267591] pci 0000:40:00.0: [10de:1c81] type 00 class 0x030000
[ 0.267610] pci 0000:40:00.0: reg 0x10: [mem 0xe9000000-0xe9ffffff]
[ 0.267626] pci 0000:40:00.0: reg 0x14: [mem 0x7fc0000000-0x7fcfffffff 64bit pref]
[ 0.267642] pci 0000:40:00.0: reg 0x1c: [mem 0x7fd0000000-0x7fd1ffffff 64bit pref]
[ 0.267653] pci 0000:40:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.267663] pci 0000:40:00.0: reg 0x30: [mem 0xea000000-0xea07ffff pref]
[ 0.267826] pci 0000:40:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x8 link at 0000:00:03.2 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.267872] pci 0000:40:00.1: [10de:0fb9] type 00 class 0x040300
[ 0.267888] pci 0000:40:00.1: reg 0x10: [mem 0xea080000-0xea083fff]
[ 0.268087] pci 0000:00:03.2: PCI bridge to [bus 40]
[ 0.268092] pci 0000:00:03.2: bridge window [io 0xe000-0xefff]
[ 0.268095] pci 0000:00:03.2: bridge window [mem 0xe9000000-0xea0fffff]
[ 0.268099] pci 0000:00:03.2: bridge window [mem 0x7fc0000000-0x7fd1ffffff 64bit pref]
[ 0.268144] pci 0000:41:00.0: [1022:148a] type 00 class 0x130000
[ 0.268186] pci 0000:41:00.0: enabling Extended Tags
[ 0.268336] pci 0000:00:07.1: PCI bridge to [bus 41]
[ 0.268396] pci 0000:42:00.0: [1022:1485] type 00 class 0x130000
[ 0.268446] pci 0000:42:00.0: enabling Extended Tags
[ 0.268603] pci 0000:42:00.1: [1022:1486] type 00 class 0x108000
[ 0.268626] pci 0000:42:00.1: reg 0x18: [mem 0xec300000-0xec3fffff]
[ 0.268644] pci 0000:42:00.1: reg 0x24: [mem 0xec408000-0xec409fff]
[ 0.268656] pci 0000:42:00.1: enabling Extended Tags
[ 0.268794] pci 0000:42:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.268813] pci 0000:42:00.3: reg 0x10: [mem 0xec200000-0xec2fffff 64bit]
[ 0.268857] pci 0000:42:00.3: enabling Extended Tags
[ 0.268924] pci 0000:42:00.3: PME# supported from D0 D3hot D3cold
[ 0.269007] pci 0000:42:00.4: [1022:1487] type 00 class 0x040300
[ 0.269020] pci 0000:42:00.4: reg 0x10: [mem 0xec400000-0xec407fff]
[ 0.269059] pci 0000:42:00.4: enabling Extended Tags
[ 0.269122] pci 0000:42:00.4: PME# supported from D0 D3hot D3cold
[ 0.269219] pci 0000:00:08.1: PCI bridge to [bus 42]
[ 0.269225] pci 0000:00:08.1: bridge window [mem 0xec200000-0xec4fffff]
[ 0.269553] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.269592] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.269623] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.269663] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.269699] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.269728] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.269757] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.269787] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.270377] ACPI: EC: interrupt unblocked
[ 0.270379] ACPI: EC: event unblocked
[ 0.270385] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.270386] ACPI: EC: GPE=0x2
[ 0.270387] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 0.270389] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.270420] iommu: Default domain type: Passthrough (set via kernel command line)
[ 0.270420] SCSI subsystem initialized
[ 0.270420] libata version 3.00 loaded.
[ 0.272488] pps_core: LinuxPPS API ver. 1 registered
[ 0.272490] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.272492] PTP clock support registered
[ 0.272497] EDAC MC: Ver: 3.0.0
[ 0.272707] Registered efivars operations
[ 0.272707] NetLabel: Initializing
[ 0.272707] NetLabel: domain hash size = 128
[ 0.272707] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.272707] NetLabel: unlabeled traffic allowed by default
[ 0.272707] mctp: management component transport protocol core
[ 0.272707] NET: Registered PF_MCTP protocol family
[ 0.272707] PCI: Using ACPI for IRQ routing
[ 0.278581] PCI: pci_cache_line_size set to 64 bytes
[ 0.278760] e820: reserve RAM buffer [mem 0x09d1f000-0x0bffffff]
[ 0.278761] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.278761] e820: reserve RAM buffer [mem 0x76dfe018-0x77ffffff]
[ 0.278762] e820: reserve RAM buffer [mem 0x76e1e018-0x77ffffff]
[ 0.278763] e820: reserve RAM buffer [mem 0x76e3e018-0x77ffffff]
[ 0.278763] e820: reserve RAM buffer [mem 0x76e4e018-0x77ffffff]
[ 0.278763] e820: reserve RAM buffer [mem 0xa3103000-0xa3ffffff]
[ 0.278764] e820: reserve RAM buffer [mem 0xa43a7000-0xa7ffffff]
[ 0.278764] e820: reserve RAM buffer [mem 0xa6549000-0xa7ffffff]
[ 0.278765] e820: reserve RAM buffer [mem 0xa685c000-0xa7ffffff]
[ 0.278765] e820: reserve RAM buffer [mem 0xa9ef2000-0xabffffff]
[ 0.278766] e820: reserve RAM buffer [mem 0xad000000-0xafffffff]
[ 0.278766] e820: reserve RAM buffer [mem 0x84f300000-0x84fffffff]
[ 0.278772] pci 0000:3f:00.0: vgaarb: setting as boot VGA device
[ 0.278772] pci 0000:3f:00.0: vgaarb: bridge control possible
[ 0.278772] pci 0000:3f:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.278772] pci 0000:40:00.0: vgaarb: bridge control possible
[ 0.278772] pci 0000:40:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.278772] vgaarb: loaded
[ 0.278772] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.278772] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.280058] clocksource: Switched to clocksource tsc-early
[ 0.283836] VFS: Disk quotas dquot_6.6.0
[ 0.283845] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.283904] AppArmor: AppArmor Filesystem Enabled
[ 0.283922] pnp: PnP ACPI init
[ 0.283979] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.284042] system 00:01: [mem 0xfd200000-0xfd2fffff] has been reserved
[ 0.284155] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.284157] system 00:03: [io 0x0200-0x021f] has been reserved
[ 0.284334] pnp 00:04: [dma 0 disabled]
[ 0.284516] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.284519] system 00:05: [io 0x040b] has been reserved
[ 0.284520] system 00:05: [io 0x04d6] has been reserved
[ 0.284521] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.284523] system 00:05: [io 0x0c14] has been reserved
[ 0.284524] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.284525] system 00:05: [io 0x0c52] has been reserved
[ 0.284526] system 00:05: [io 0x0c6c] has been reserved
[ 0.284528] system 00:05: [io 0x0c6f] has been reserved
[ 0.284529] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.284530] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.284531] system 00:05: [io 0x0b00-0x0b0f] has been reserved
[ 0.284533] system 00:05: [io 0x0b20-0x0b3f] has been reserved
[ 0.284534] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.284535] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.284537] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.284538] system 00:05: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.284540] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.284542] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.284544] system 00:05: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.284545] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.284547] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.284978] pnp: PnP ACPI: found 6 devices
[ 0.290204] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.290248] NET: Registered PF_INET protocol family
[ 0.290380] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.292115] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.292132] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.292135] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.292272] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.292335] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.292427] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.292456] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.292487] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.292549] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.292553] NET: Registered PF_XDP protocol family
[ 0.292557] pci 0000:06:01.0: bridge window [io 0x1000-0x0fff] to [bus 08-1f] add_size 1000
[ 0.292559] pci 0000:06:03.0: bridge window [io 0x1000-0x0fff] to [bus 21-38] add_size 1000
[ 0.292561] pci 0000:05:00.0: bridge window [io 0x1000-0x0fff] to [bus 06-38] add_size 2000
[ 0.292563] pci 0000:03:02.0: bridge window [io 0x1000-0x0fff] to [bus 05-38] add_size 2000
[ 0.292566] pci 0000:02:00.0: bridge window [io 0x1000-0x0fff] to [bus 03-3e] add_size 2000
[ 0.292567] pci 0000:00:01.2: bridge window [io 0x1000-0x0fff] to [bus 02-3e] add_size 2000
[ 0.292572] pci 0000:00:01.2: BAR 13: assigned [io 0x1000-0x2fff]
[ 0.292573] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.292578] pci 0000:00:01.1: bridge window [mem 0xec500000-0xec5fffff]
[ 0.292585] pci 0000:02:00.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 0.292586] pci 0000:03:02.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 0.292588] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.292594] pci 0000:03:00.0: bridge window [mem 0xe8100000-0xe81fffff]
[ 0.292605] pci 0000:05:00.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 0.292607] pci 0000:06:01.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.292608] pci 0000:06:03.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.292610] pci 0000:06:00.0: PCI bridge to [bus 07]
[ 0.292617] pci 0000:06:00.0: bridge window [mem 0xe7100000-0xe71fffff]
[ 0.292623] pci 0000:06:00.0: bridge window [mem 0x7fb5100000-0x7fb51fffff 64bit pref]
[ 0.292633] pci 0000:06:01.0: PCI bridge to [bus 08-1f]
[ 0.292636] pci 0000:06:01.0: bridge window [io 0x1000-0x1fff]
[ 0.292644] pci 0000:06:01.0: bridge window [mem 0xd0000000-0xe6efffff]
[ 0.292649] pci 0000:06:01.0: bridge window [mem 0x7f90000000-0x7fb4ffffff 64bit pref]
[ 0.292659] pci 0000:06:02.0: PCI bridge to [bus 20]
[ 0.292667] pci 0000:06:02.0: bridge window [mem 0xe7000000-0xe70fffff]
[ 0.292681] pci 0000:06:03.0: PCI bridge to [bus 21-38]
[ 0.292684] pci 0000:06:03.0: bridge window [io 0x2000-0x2fff]
[ 0.292691] pci 0000:06:03.0: bridge window [mem 0xb8000000-0xceffffff]
[ 0.292697] pci 0000:06:03.0: bridge window [mem 0x7f60000000-0x7f84ffffff 64bit pref]
[ 0.292707] pci 0000:05:00.0: PCI bridge to [bus 06-38]
[ 0.292710] pci 0000:05:00.0: bridge window [io 0x1000-0x2fff]
[ 0.292717] pci 0000:05:00.0: bridge window [mem 0xb8000000-0xe71fffff]
[ 0.292723] pci 0000:05:00.0: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292732] pci 0000:03:02.0: PCI bridge to [bus 05-38]
[ 0.292735] pci 0000:03:02.0: bridge window [io 0x1000-0x2fff]
[ 0.292741] pci 0000:03:02.0: bridge window [mem 0xb8000000-0xe71fffff]
[ 0.292746] pci 0000:03:02.0: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292754] pci 0000:03:03.0: PCI bridge to [bus 39]
[ 0.292760] pci 0000:03:03.0: bridge window [mem 0xe7400000-0xe78fffff]
[ 0.292771] pci 0000:03:04.0: PCI bridge to [bus 3a]
[ 0.292777] pci 0000:03:04.0: bridge window [mem 0xe8000000-0xe80fffff]
[ 0.292788] pci 0000:03:05.0: PCI bridge to [bus 3b]
[ 0.292794] pci 0000:03:05.0: bridge window [mem 0xe7c00000-0xe7dfffff]
[ 0.292806] pci 0000:03:08.0: PCI bridge to [bus 3c]
[ 0.292812] pci 0000:03:08.0: bridge window [mem 0xe7a00000-0xe7bfffff]
[ 0.292823] pci 0000:03:09.0: PCI bridge to [bus 3d]
[ 0.292829] pci 0000:03:09.0: bridge window [mem 0xe7f00000-0xe7ffffff]
[ 0.292840] pci 0000:03:0a.0: PCI bridge to [bus 3e]
[ 0.292846] pci 0000:03:0a.0: bridge window [mem 0xe7e00000-0xe7efffff]
[ 0.292857] pci 0000:02:00.0: PCI bridge to [bus 03-3e]
[ 0.292860] pci 0000:02:00.0: bridge window [io 0x1000-0x2fff]
[ 0.292866] pci 0000:02:00.0: bridge window [mem 0xb8000000-0xe81fffff]
[ 0.292870] pci 0000:02:00.0: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292878] pci 0000:00:01.2: PCI bridge to [bus 02-3e]
[ 0.292880] pci 0000:00:01.2: bridge window [io 0x1000-0x2fff]
[ 0.292884] pci 0000:00:01.2: bridge window [mem 0xb8000000-0xe81fffff]
[ 0.292887] pci 0000:00:01.2: bridge window [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292892] pci 0000:00:03.1: PCI bridge to [bus 3f]
[ 0.292894] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.292897] pci 0000:00:03.1: bridge window [mem 0xeb000000-0xec0fffff]
[ 0.292900] pci 0000:00:03.1: bridge window [mem 0x7fe0000000-0x7ff1ffffff 64bit pref]
[ 0.292905] pci 0000:00:03.2: PCI bridge to [bus 40]
[ 0.292907] pci 0000:00:03.2: bridge window [io 0xe000-0xefff]
[ 0.292911] pci 0000:00:03.2: bridge window [mem 0xe9000000-0xea0fffff]
[ 0.292913] pci 0000:00:03.2: bridge window [mem 0x7fc0000000-0x7fd1ffffff 64bit pref]
[ 0.292918] pci 0000:00:07.1: PCI bridge to [bus 41]
[ 0.292927] pci 0000:00:08.1: PCI bridge to [bus 42]
[ 0.292931] pci 0000:00:08.1: bridge window [mem 0xec200000-0xec4fffff]
[ 0.292938] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.292939] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.292940] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.292942] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.292943] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.292944] pci_bus 0000:00: resource 9 [mem 0xb0000000-0xefffffff window]
[ 0.292945] pci_bus 0000:00: resource 10 [mem 0x850000000-0x7fffffffff window]
[ 0.292947] pci_bus 0000:01: resource 1 [mem 0xec500000-0xec5fffff]
[ 0.292948] pci_bus 0000:02: resource 0 [io 0x1000-0x2fff]
[ 0.292949] pci_bus 0000:02: resource 1 [mem 0xb8000000-0xe81fffff]
[ 0.292951] pci_bus 0000:02: resource 2 [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292952] pci_bus 0000:03: resource 0 [io 0x1000-0x2fff]
[ 0.292953] pci_bus 0000:03: resource 1 [mem 0xb8000000-0xe81fffff]
[ 0.292954] pci_bus 0000:03: resource 2 [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292956] pci_bus 0000:04: resource 1 [mem 0xe8100000-0xe81fffff]
[ 0.292957] pci_bus 0000:05: resource 0 [io 0x1000-0x2fff]
[ 0.292958] pci_bus 0000:05: resource 1 [mem 0xb8000000-0xe71fffff]
[ 0.292959] pci_bus 0000:05: resource 2 [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292961] pci_bus 0000:06: resource 0 [io 0x1000-0x2fff]
[ 0.292962] pci_bus 0000:06: resource 1 [mem 0xb8000000-0xe71fffff]
[ 0.292963] pci_bus 0000:06: resource 2 [mem 0x7f60000000-0x7fb51fffff 64bit pref]
[ 0.292964] pci_bus 0000:07: resource 1 [mem 0xe7100000-0xe71fffff]
[ 0.292966] pci_bus 0000:07: resource 2 [mem 0x7fb5100000-0x7fb51fffff 64bit pref]
[ 0.292967] pci_bus 0000:08: resource 0 [io 0x1000-0x1fff]
[ 0.292968] pci_bus 0000:08: resource 1 [mem 0xd0000000-0xe6efffff]
[ 0.292969] pci_bus 0000:08: resource 2 [mem 0x7f90000000-0x7fb4ffffff 64bit pref]
[ 0.292971] pci_bus 0000:20: resource 1 [mem 0xe7000000-0xe70fffff]
[ 0.292972] pci_bus 0000:21: resource 0 [io 0x2000-0x2fff]
[ 0.292973] pci_bus 0000:21: resource 1 [mem 0xb8000000-0xceffffff]
[ 0.292974] pci_bus 0000:21: resource 2 [mem 0x7f60000000-0x7f84ffffff 64bit pref]
[ 0.292976] pci_bus 0000:39: resource 1 [mem 0xe7400000-0xe78fffff]
[ 0.292977] pci_bus 0000:3a: resource 1 [mem 0xe8000000-0xe80fffff]
[ 0.292978] pci_bus 0000:3b: resource 1 [mem 0xe7c00000-0xe7dfffff]
[ 0.292979] pci_bus 0000:3c: resource 1 [mem 0xe7a00000-0xe7bfffff]
[ 0.292981] pci_bus 0000:3d: resource 1 [mem 0xe7f00000-0xe7ffffff]
[ 0.292982] pci_bus 0000:3e: resource 1 [mem 0xe7e00000-0xe7efffff]
[ 0.292983] pci_bus 0000:3f: resource 0 [io 0xf000-0xffff]
[ 0.292984] pci_bus 0000:3f: resource 1 [mem 0xeb000000-0xec0fffff]
[ 0.292985] pci_bus 0000:3f: resource 2 [mem 0x7fe0000000-0x7ff1ffffff 64bit pref]
[ 0.292987] pci_bus 0000:40: resource 0 [io 0xe000-0xefff]
[ 0.292988] pci_bus 0000:40: resource 1 [mem 0xe9000000-0xea0fffff]
[ 0.292989] pci_bus 0000:40: resource 2 [mem 0x7fc0000000-0x7fd1ffffff 64bit pref]
[ 0.292991] pci_bus 0000:42: resource 1 [mem 0xec200000-0xec4fffff]
[ 0.293075] pci 0000:05:00.0: CLS mismatch (64 != 128), using 64 bytes
[ 0.293454] pci 0000:3f:00.1: D0 power state depends on 0000:3f:00.0
[ 0.293524] pci 0000:40:00.1: D0 power state depends on 0000:40:00.0
[ 0.293651] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.293672] Trying to unpack rootfs image as initramfs...
[ 0.293674] pci 0000:00:01.0: Adding to iommu group 0
[ 0.293682] pci 0000:00:01.1: Adding to iommu group 1
[ 0.293689] pci 0000:00:01.2: Adding to iommu group 2
[ 0.293695] pci 0000:00:02.0: Adding to iommu group 3
[ 0.293704] pci 0000:00:03.0: Adding to iommu group 4
[ 0.293710] pci 0000:00:03.1: Adding to iommu group 5
[ 0.293716] pci 0000:00:03.2: Adding to iommu group 6
[ 0.293723] pci 0000:00:04.0: Adding to iommu group 7
[ 0.293729] pci 0000:00:05.0: Adding to iommu group 8
[ 0.293737] pci 0000:00:07.0: Adding to iommu group 9
[ 0.293743] pci 0000:00:07.1: Adding to iommu group 10
[ 0.293752] pci 0000:00:08.0: Adding to iommu group 11
[ 0.293758] pci 0000:00:08.1: Adding to iommu group 12
[ 0.293766] pci 0000:00:14.0: Adding to iommu group 13
[ 0.293770] pci 0000:00:14.3: Adding to iommu group 13
[ 0.293791] pci 0000:00:18.0: Adding to iommu group 14
[ 0.293796] pci 0000:00:18.1: Adding to iommu group 14
[ 0.293801] pci 0000:00:18.2: Adding to iommu group 14
[ 0.293805] pci 0000:00:18.3: Adding to iommu group 14
[ 0.293810] pci 0000:00:18.4: Adding to iommu group 14
[ 0.293815] pci 0000:00:18.5: Adding to iommu group 14
[ 0.293819] pci 0000:00:18.6: Adding to iommu group 14
[ 0.293824] pci 0000:00:18.7: Adding to iommu group 14
[ 0.293831] pci 0000:01:00.0: Adding to iommu group 15
[ 0.293837] pci 0000:02:00.0: Adding to iommu group 16
[ 0.293866] pci 0000:03:00.0: Adding to iommu group 17
[ 0.293894] pci 0000:03:02.0: Adding to iommu group 18
[ 0.293923] pci 0000:03:03.0: Adding to iommu group 19
[ 0.293952] pci 0000:03:04.0: Adding to iommu group 20
[ 0.293980] pci 0000:03:05.0: Adding to iommu group 21
[ 0.293988] pci 0000:03:08.0: Adding to iommu group 22
[ 0.293996] pci 0000:03:09.0: Adding to iommu group 23
[ 0.294004] pci 0000:03:0a.0: Adding to iommu group 24
[ 0.294033] pci 0000:04:00.0: Adding to iommu group 25
[ 0.294062] pci 0000:05:00.0: Adding to iommu group 26
[ 0.294092] pci 0000:06:00.0: Adding to iommu group 27
[ 0.294121] pci 0000:06:01.0: Adding to iommu group 28
[ 0.294150] pci 0000:06:02.0: Adding to iommu group 29
[ 0.294179] pci 0000:06:03.0: Adding to iommu group 30
[ 0.294212] pci 0000:07:00.0: Adding to iommu group 31
[ 0.294245] pci 0000:20:00.0: Adding to iommu group 32
[ 0.294274] pci 0000:39:00.0: Adding to iommu group 33
[ 0.294303] pci 0000:3a:00.0: Adding to iommu group 34
[ 0.294332] pci 0000:3b:00.0: Adding to iommu group 35
[ 0.294335] pci 0000:3c:00.0: Adding to iommu group 22
[ 0.294338] pci 0000:3c:00.1: Adding to iommu group 22
[ 0.294341] pci 0000:3c:00.3: Adding to iommu group 22
[ 0.294344] pci 0000:3d:00.0: Adding to iommu group 23
[ 0.294347] pci 0000:3e:00.0: Adding to iommu group 24
[ 0.294356] pci 0000:3f:00.0: Adding to iommu group 36
[ 0.294364] pci 0000:3f:00.1: Adding to iommu group 36
[ 0.294373] pci 0000:40:00.0: Adding to iommu group 37
[ 0.294380] pci 0000:40:00.1: Adding to iommu group 37
[ 0.294386] pci 0000:41:00.0: Adding to iommu group 38
[ 0.294394] pci 0000:42:00.0: Adding to iommu group 39
[ 0.294403] pci 0000:42:00.1: Adding to iommu group 40
[ 0.294411] pci 0000:42:00.3: Adding to iommu group 41
[ 0.294419] pci 0000:42:00.4: Adding to iommu group 42
[ 0.295133] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.295135] AMD-Vi: Extended features (0x58f77ef22294a5a): PPR NX GT IA PC GA_vAPIC
[ 0.295138] AMD-Vi: Interrupt remapping enabled
[ 0.295203] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.295210] software IO TLB: mapped [mem 0x000000009baf7000-0x000000009faf7000] (64MB)
[ 0.295460] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 0.295462] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 0.295464] LVT offset 0 assigned for vector 0x400
[ 0.295677] perf: AMD IBS detected (0x000003ff)
[ 0.295683] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.296079] Initialise system trusted keyrings
[ 0.296085] Key type blacklist registered
[ 0.296103] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[ 0.296534] zbud: loaded
[ 0.296642] integrity: Platform Keyring initialized
[ 0.298959] Key type asymmetric registered
[ 0.298960] Asymmetric key parser 'x509' registered
[ 1.312021] tsc: Refined TSC clocksource calibration: 3399.998 MHz
[ 1.312031] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x31024cfe468, max_idle_ns: 440795307017 ns
[ 1.312534] clocksource: Switched to clocksource tsc
[ 2.025833] Freeing initrd memory: 79684K
[ 2.028841] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 2.028850] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.028889] io scheduler mq-deadline registered
[ 2.028890] io scheduler kyber registered
[ 2.028903] io scheduler bfq registered
[ 2.031146] pcieport 0000:00:01.1: PME: Signaling with IRQ 29
[ 2.031196] pcieport 0000:00:01.1: AER: enabled with IRQ 29
[ 2.031321] pcieport 0000:00:01.2: PME: Signaling with IRQ 30
[ 2.031408] pcieport 0000:00:01.2: AER: enabled with IRQ 30
[ 2.031534] pcieport 0000:00:03.1: PME: Signaling with IRQ 31
[ 2.031576] pcieport 0000:00:03.1: AER: enabled with IRQ 31
[ 2.031707] pcieport 0000:00:03.2: PME: Signaling with IRQ 32
[ 2.031747] pcieport 0000:00:03.2: AER: enabled with IRQ 32
[ 2.031903] pcieport 0000:00:07.1: PME: Signaling with IRQ 34
[ 2.031942] pcieport 0000:00:07.1: AER: enabled with IRQ 34
[ 2.032056] pcieport 0000:00:08.1: PME: Signaling with IRQ 35
[ 2.032100] pcieport 0000:00:08.1: AER: enabled with IRQ 35
[ 2.034943] pcieport 0000:06:01.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 2.035498] pcieport 0000:06:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 2.035717] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 2.036471] Estimated ratio of average max frequency by base frequency (times 1024): 1277
[ 2.036479] Monitor-Mwait will be used to enter C-1 state
[redacted]
[ 2.038166] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 2.038320] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 2.039522] Non-volatile memory driver v1.3
[ 2.039524] Linux agpgart interface v0.103
[ 2.120483] ACPI: bus type drm_connector registered
[ 2.122166] ahci 0000:3d:00.0: version 3.0
[ 2.122302] ahci 0000:3d:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 2.122307] ahci 0000:3d:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 2.122445] scsi host0: ahci
[ 2.122480] ata1: SATA max UDMA/133 abar m2048@0xe7f00000 port 0xe7f00100 irq 51
[ 2.122613] ahci 0000:3e:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 2.122617] ahci 0000:3e:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 2.122732] scsi host1: ahci
[ 2.122750] ata2: SATA max UDMA/133 abar m2048@0xe7e00000 port 0xe7e00100 irq 52
[ 2.122784] i8042: PNP: No PS/2 controller found.
[ 2.122814] mousedev: PS/2 mouse device common for all mice
[ 2.122854] rtc_cmos 00:02: RTC can wake from S4
[ 2.123045] rtc_cmos 00:02: registered as rtc0
[ 2.123076] rtc_cmos 00:02: setting system clock to 2022-11-15T00:41:57 UTC (1668472917)
[ 2.123087] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 2.123483] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.123555] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 2.130785] Console: switching to colour frame buffer device 128x48
[ 2.135596] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 2.137962] EFI Variables Facility v0.08 2004-May-17
[ 2.139236] hid: raw HID events driver (C) Jiri Kosina
[ 2.139326] drop_monitor: Initializing network drop monitor service
[ 2.140424] Cannot find struct bpf_struct_ops_bpf_dummy_ops in btf_vmlinux
[ 2.140460] Cannot find struct bpf_struct_ops_tcp_congestion_ops in btf_vmlinux
[ 2.140611] NET: Registered PF_INET6 protocol family
[ 2.142903] Segment Routing with IPv6
[ 2.142909] RPL Segment Routing with IPv6
[ 2.142918] In-situ OAM (IOAM) with IPv6
[ 2.144400] microcode: CPU0: patch_level=0x0a201016
[redacted]
[ 2.147855] microcode: Microcode Update Driver: v2.2.
[ 2.148273] resctrl: L3 allocation detected
[ 2.148513] resctrl: MB allocation detected
[ 2.148609] resctrl: L3 monitoring detected
[ 2.148702] IPI shorthand broadcast: enabled
[ 2.148803] sched_clock: Marking stable (2176258397, -27995280)->(2267546284, -119283167)
[ 2.149370] registered taskstats version 1
[ 2.150569] Loading compiled-in X.509 certificates
[ 2.176161] Loaded X.509 cert 'Kernel OBS Project: 1fb41512acbc8eebdf828d877e4367bf6c719af3'
[ 2.176561] zswap: loaded using pool lzo/zbud
[ 2.176926] page_owner is disabled
[redacted]
[ 2.182433] ima: Allocated hash algorithm: sha256
[ 2.320316] ima: No architecture policies found
[ 2.322932] evm: Initialising EVM extended attributes:
[ 2.323112] evm: security.selinux
[ 2.323243] evm: security.SMACK64 (disabled)
[ 2.323375] evm: security.SMACK64EXEC (disabled)
[ 2.323507] evm: security.SMACK64TRANSMUTE (disabled)
[ 2.323639] evm: security.SMACK64MMAP (disabled)
[ 2.323772] evm: security.apparmor
[ 2.323905] evm: security.ima
[ 2.324042] evm: security.capability
[ 2.324174] evm: HMAC attrs: 0x1
[ 2.384860] PM: Magic number: 14:287:658
[ 2.385269] RAS: Correctable Errors collector initialized.
[ 2.434552] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.434777] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.436385] Freeing unused kernel image (initmem) memory: 2924K
[ 2.436567] Write protecting the kernel read-only data: 24576k
[ 2.437175] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 2.437502] Freeing unused kernel image (rodata/data gap) memory: 812K
[ 2.437653] Run /init as init process
[ 2.437799] with arguments:
[ 2.437799] /init
[ 2.437800] with environment:
[ 2.437800] HOME=/
[ 2.437800] TERM=linux
[ 2.437801] BOOT_IMAGE=/boot/vmlinuz-5.19.8-lp153.3.g14c495f-default
[ 2.446986] systemd[1]: systemd 246.16+suse.259.ge7211d27e1 running in system mode. (+PAM +AUDIT +SELINUX -IMA +APPARMOR -SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 2.447710] systemd[1]: Detected architecture x86-64.
[ 2.447878] systemd[1]: Running in initial RAM disk.
[ 2.517331] systemd[1]: Set hostname to <suse>.
[ 2.545812] systemd[1]: Queued start job for default target Initrd Default Target.
[ 2.551396] systemd[1]: Reached target Local File Systems.
[ 2.551746] systemd[1]: Reached target Slices.
[ 2.552088] systemd[1]: Reached target Swap.
[ 2.552409] systemd[1]: Reached target Timers.
[ 2.552751] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.553096] systemd[1]: Listening on Journal Socket.
[ 2.553433] systemd[1]: Listening on udev Control Socket.
[ 2.553757] systemd[1]: Listening on udev Kernel Socket.
[ 2.554058] systemd[1]: Reached target Sockets.
[ 2.554656] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 2.555340] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 2.556372] systemd[1]: Starting Journal Service...
[ 2.557071] systemd[1]: Starting Load Kernel Modules...
[ 2.557746] systemd[1]: Starting Setup Virtual Console...
[ 2.558317] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 2.559032] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.559986] i2c_dev: i2c /dev entries driver
[ 2.561604] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.564783] alua: device handler registered
[ 2.565723] emc: device handler registered
[ 2.566728] rdac: device handler registered
[ 2.566812] systemd[1]: Finished Setup Virtual Console.
[ 2.567765] systemd[1]: Starting dracut ask for additional cmdline parameters...
[ 2.572918] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 2.573847] device-mapper: uevent: version 1.0.3
[ 2.574186] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: [email protected]
[ 2.576110] systemd[1]: Finished dracut ask for additional cmdline parameters.
[ 2.577281] systemd[1]: Starting dracut cmdline hook...
[ 2.577857] systemd[1]: Finished Load Kernel Modules.
[ 2.578576] systemd[1]: Starting Apply Kernel Variables...
[ 2.580947] systemd[1]: Finished Apply Kernel Variables.
[ 2.590144] systemd[1]: Started Journal Service.
[ 2.630065] VFIO - User Level meta-driver version: 0.3
[ 2.636464] vfio-pci 0000:3f:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[ 2.639012] vfio_pci: add [10de:1b82[ffffffff:ffffffff]] class 0x000000/00000000
[ 2.720540] vfio_pci: add [10de:10f0[ffffffff:ffffffff]] class 0x000000/00000000
[ 2.783315] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 2.784058] ACPI: button: Power Button [PWRB]
[ 2.784400] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 2.784814] ACPI: button: Power Button [PWRF]
[ 2.787873] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.788014] acpi PNP0C14:03: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was on PNP0C14:00)
[ 2.788832] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.788891] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.789941] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.790786] acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.797322] ACPI: bus type USB registered
[ 2.797696] nvme nvme0: pci function 0000:01:00.0
[ 2.798869] usbcore: registered new interface driver usbfs
[ 2.799003] nvme nvme1: pci function 0000:04:00.0
[ 2.799131] ccp 0000:42:00.1: enabling device (0000 -> 0002)
[ 2.799277] ccp 0000:42:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[ 2.799308] ccp 0000:42:00.1: psp enabled
[ 2.799439] usbcore: registered new interface driver hub
[ 2.800795] usbcore: registered new device driver usb
[ 2.801031] nvidia: loading out-of-tree module taints kernel.
[ 2.801041] nvidia: module license 'NVIDIA' taints kernel.
[ 2.801436] nvidia: module license 'NVIDIA' taints kernel.
[ 2.801850] Disabling lock debugging due to kernel taint
[ 2.803851] AVX2 version of gcm_enc/dec engaged.
[ 2.803904] AES CTR mode by8 optimization enabled
[ 2.809957] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.813786] nvme nvme1: Shutdown timeout set to 8 seconds
[ 2.813818] nvme nvme0: Shutdown timeout set to 8 seconds
[ 2.833646] nvme nvme0: allocated 64 MiB host memory buffer.
[ 2.833708] nvme nvme1: allocated 64 MiB host memory buffer.
[ 2.957052] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 2.958689] nvidia 0000:40:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 2.970484] nvme nvme1: 12/0/0 default/read/poll queues
[ 2.973254] nvme nvme0: 12/0/0 default/read/poll queues
[ 2.984872] nvme1n1: p1 p2 p3 p4 p5
[ 2.988315] nvme0n1: p1 p2
[ 2.998034] xhci_hcd 0000:20:00.0: xHCI Host Controller
[ 2.998057] xhci_hcd 0000:20:00.0: new USB bus registered, assigned bus number 1
[ 2.999203] xhci_hcd 0000:20:00.0: hcc params 0x20007fc1 hci version 0x110 quirks 0x0000000200009810
[ 2.999523] xhci_hcd 0000:20:00.0: xHCI Host Controller
[ 2.999533] xhci_hcd 0000:20:00.0: new USB bus registered, assigned bus number 2
[ 2.999543] xhci_hcd 0000:20:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.001336] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 3.001352] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.001364] usb usb1: Product: xHCI Host Controller
[ 3.001373] usb usb1: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.001387] usb usb1: SerialNumber: 0000:20:00.0
[ 3.001812] hub 1-0:1.0: USB hub found
[ 3.002196] hub 1-0:1.0: 2 ports detected
[ 3.003629] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 3.003641] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.003652] usb usb2: Product: xHCI Host Controller
[ 3.003659] usb usb2: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.003670] usb usb2: SerialNumber: 0000:20:00.0
[ 3.003982] hub 2-0:1.0: USB hub found
[ 3.005192] hub 2-0:1.0: 2 ports detected
[ 3.005595] xhci_hcd 0000:3c:00.1: xHCI Host Controller
[ 3.005606] xhci_hcd 0000:3c:00.1: new USB bus registered, assigned bus number 3
[ 3.005769] xhci_hcd 0000:3c:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 3.006553] xhci_hcd 0000:3c:00.1: xHCI Host Controller
[ 3.006563] xhci_hcd 0000:3c:00.1: new USB bus registered, assigned bus number 4
[ 3.006574] xhci_hcd 0000:3c:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.006602] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 3.006611] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.006621] usb usb3: Product: xHCI Host Controller
[ 3.006850] usb usb3: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.006851] usb usb3: SerialNumber: 0000:3c:00.1
[ 3.007119] hub 3-0:1.0: USB hub found
[ 3.007569] hub 3-0:1.0: 6 ports detected
[ 3.009570] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.009882] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 3.010195] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.010391] usb usb4: Product: xHCI Host Controller
[ 3.010562] usb usb4: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.010728] usb usb4: SerialNumber: 0000:3c:00.1
[ 3.011005] hub 4-0:1.0: USB hub found
[ 3.011173] hub 4-0:1.0: 4 ports detected
[ 3.011775] xhci_hcd 0000:3c:00.3: xHCI Host Controller
[ 3.011931] xhci_hcd 0000:3c:00.3: new USB bus registered, assigned bus number 5
[ 3.013681] clocksource: timekeeping watchdog on CPU5: hpet wd-wd read-back delay of 113980ns
[ 3.013682] clocksource: wd-tsc-wd read-back delay of 229009ns, clock-skew test skipped!
[ 3.013791] xhci_hcd 0000:3c:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 3.014232] xhci_hcd 0000:3c:00.3: xHCI Host Controller
[ 3.014684] xhci_hcd 0000:3c:00.3: new USB bus registered, assigned bus number 6
[ 3.014685] xhci_hcd 0000:3c:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.014728] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 3.015367] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.015368] usb usb5: Product: xHCI Host Controller
[ 3.015368] usb usb5: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.015369] usb usb5: SerialNumber: 0000:3c:00.3
[ 3.015521] hub 5-0:1.0: USB hub found
[ 3.017190] hub 5-0:1.0: 6 ports detected
[ 3.017819] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.018048] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 3.018243] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.018412] usb usb6: Product: xHCI Host Controller
[ 3.018579] usb usb6: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.018747] usb usb6: SerialNumber: 0000:3c:00.3
[ 3.019005] hub 6-0:1.0: USB hub found
[ 3.019178] hub 6-0:1.0: 4 ports detected
[ 3.019498] usb: port power management may be unreliable
[ 3.021217] xhci_hcd 0000:42:00.3: xHCI Host Controller
[ 3.021387] xhci_hcd 0000:42:00.3: new USB bus registered, assigned bus number 7
[ 3.021784] xhci_hcd 0000:42:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 3.022810] xhci_hcd 0000:42:00.3: xHCI Host Controller
[ 3.022971] xhci_hcd 0000:42:00.3: new USB bus registered, assigned bus number 8
[ 3.023133] xhci_hcd 0000:42:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.023322] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 3.023484] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.023653] usb usb7: Product: xHCI Host Controller
[ 3.023813] usb usb7: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.023975] usb usb7: SerialNumber: 0000:42:00.3
[ 3.025591] hub 7-0:1.0: USB hub found
[ 3.025754] hub 7-0:1.0: 4 ports detected
[ 3.026209] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.026378] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 3.026539] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.026698] usb usb8: Product: xHCI Host Controller
[ 3.026857] usb usb8: Manufacturer: Linux 5.19.8-lp153.3.g14c495f-default xhci-hcd
[ 3.027017] usb usb8: SerialNumber: 0000:42:00.3
[ 3.027293] hub 8-0:1.0: USB hub found
[ 3.027453] hub 8-0:1.0: 4 ports detected
[ 3.090844] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[ 3.091070] NVRM: This can occur when a driver such as:
NVRM: nouveau, rivafb, nvidiafb or rivatv
NVRM: was loaded and obtained ownership of the NVIDIA device(s).
[ 3.091646] NVRM: Try unloading the conflicting kernel module (and/or
NVRM: reconfigure your kernel without the conflicting
NVRM: driver(s)), then try loading the NVIDIA kernel module
NVRM: again.
[ 3.093819] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 3.167679] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 515.65.01 Wed Jul 20 13:43:59 UTC 2022
[ 3.202529] [drm] [nvidia-drm] [GPU ID 0x00004000] Loading driver
[ 3.203761] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:40:00.0 on minor 1
[ 3.292032] usb 5-2: new full-speed USB device number 2 using xhci_hcd
[ 3.342626] usb 7-2: new low-speed USB device number 2 using xhci_hcd
[ 3.393404] usb 4-4: new SuperSpeed USB device number 2 using xhci_hcd
[ 3.445526] usb 4-4: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00
[ 3.445697] usb 4-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.445860] usb 4-4: Product: Flash Drive FIT
[ 3.446019] usb 4-4: Manufacturer: Samsung
[ 3.446176] usb 4-4: SerialNumber: 0346922050000160
[ 3.500111] usb-storage 4-4:1.0: USB Mass Storage device detected
[ 3.501102] usb-storage 4-4:1.0: Quirks match for vid 090c pid 1000: 400
[ 3.501485] scsi host2: usb-storage 4-4:1.0
[ 3.501717] usbcore: registered new interface driver usb-storage
[ 3.514676] usbcore: registered new interface driver uas
[ 3.522072] clocksource: timekeeping watchdog on CPU6: hpet wd-wd read-back delay of 131511ns
[ 3.522316] clocksource: wd-tsc-wd read-back delay of 1461987ns, clock-skew test skipped!
[redacted]
[ 231.901317] systemd-journald[414]: Received SIGTERM from PID 1 (systemd).
[ 232.024700] systemd[1]: systemd 246.16+suse.259.ge7211d27e1 running in system mode. (+PAM +AUDIT +SELINUX -IMA +APPARMOR -SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 232.025182] systemd[1]: Detected architecture x86-64.
[ 232.026282] systemd[1]: Set hostname to <suse>.
[ 232.148822] systemd-sysv-generator[3403]: SysV service '/etc/init.d/vmware' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 232.230291] systemd[1]: Configuration file /etc/systemd/system/gpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 232.244971] systemd[1]: /usr/lib/systemd/system/pcscd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/pcscd/pcscd.comm → /run/pcscd/pcscd.comm; please update the unit file accordingly.
[ 232.298264] systemd[1]: initrd-switch-root.service: Succeeded.
[ 232.298675] systemd[1]: Stopped Switch Root.
[ 232.299208] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[ 232.299590] systemd[1]: Created slice Virtual Machine and Container Slice.
[ 232.299964] systemd[1]: Created slice Slice /system/getty.
[ 232.300212] systemd[1]: Created slice Slice /system/modprobe.
[ 232.300453] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 232.300689] systemd[1]: Created slice User and Session Slice.
[ 232.300959] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 232.303703] systemd[1]: Stopped target Switch Root.
[ 232.304420] systemd[1]: Stopped target Initrd File Systems.
[ 232.304880] systemd[1]: Stopped target Initrd Root File System.
[ 232.305160] systemd[1]: Reached target Slices.
[ 232.305410] systemd[1]: Reached target Swap.
[ 232.305867] systemd[1]: Reached target System Time Set.
[ 232.306159] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 232.306437] systemd[1]: Listening on LVM2 poll daemon socket.
[ 232.306675] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 232.307159] systemd[1]: Listening on udev Control Socket.
[ 232.307411] systemd[1]: Listening on udev Kernel Socket.
[ 232.308020] systemd[1]: Mounting Huge Pages File System...
[ 232.308710] systemd[1]: Mounting POSIX Message Queue File System...
[ 232.309538] systemd[1]: Mounting Kernel Debug File System...
[ 232.310441] systemd[1]: Mounting Kernel Trace File System...
[ 232.311251] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 232.311890] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 232.312781] systemd[1]: Starting Load Kernel Module configfs...
[ 232.313343] systemd[1]: Starting Load Kernel Module drm...
[ 232.313960] systemd[1]: Starting Load Kernel Module fuse...
[ 232.314273] systemd[1]: plymouth-start.service: Succeeded.
[ 232.314286] systemd[1]: plymouth-start.service: Unit process 605 (plymouthd) remains running after unit stopped.
[ 232.314327] systemd[1]: Stopped Show Plymouth Boot Screen.
[ 232.315047] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[ 232.315632] systemd[1]: plymouth-switch-root.service: Succeeded.
[ 232.315660] systemd[1]: Stopped Plymouth switch root service.
[ 232.316739] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 232.316754] systemd[1]: systemd-fsck-root.service: Succeeded.
[ 232.316787] systemd[1]: Stopped File System Check on Root Device.
[ 232.320265] systemd[1]: Stopped Journal Service.
[ 232.325871] systemd[1]: Listening on Syslog Socket.
[ 232.332500] systemd[1]: Starting Journal Service...
[ 232.333832] systemd[1]: Starting Load Kernel Modules...
[ 232.335186] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 232.335680] systemd[1]: Starting Coldplug All udev Devices...
[ 232.336259] systemd[1]: sysroot.mount: Succeeded.
[ 232.336735] systemd[1]: Mounted Huge Pages File System.
[ 232.338165] systemd[1]: Mounted POSIX Message Queue File System.
[ 232.339939] systemd[1]: Mounted Kernel Debug File System.
[ 232.342135] systemd[1]: Mounted Kernel Trace File System.
[ 232.343882] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 232.345630] systemd[1]: [email protected]: Succeeded.
[ 232.345724] systemd[1]: Finished Load Kernel Module drm.
[redacted]
[ 233.374924] igc 0000:3b:00.0 (unnamed net_device) (uninitialized): PHC added
[ 233.380338] SVM: TSC scaling supported
[ 233.380699] kvm: Nested Virtualization enabled
[ 233.380917] SVM: kvm: Nested Paging enabled
[ 233.381132] SVM: Virtual VMLOAD VMSAVE supported
[ 233.381326] SVM: Virtual GIF supported
[ 233.381507] SVM: LBR virtualization supported
[ 233.488368] igc 0000:3b:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 233.488567] igc 0000:3b:00.0 eth1: MAC: 04:42:1a:ac:c3:dc
[ 233.507399] clocksource: timekeeping watchdog on CPU18: hpet wd-wd read-back delay of 263511ns
[ 233.507703] clocksource: wd-tsc-wd read-back delay of 1392844ns, clock-skew test skipped!
[ 233.518240] usb 5-4.2: Warning! Unlikely big volume range (=1008), cval->res is probably wrong.
[ 233.521581] usb 5-4.2: [49] FU [PCM Playback Volume] ch = 2, val = -16129/-1/16
[ 233.606441] usb 5-4.2: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
[ 233.606656] usb 5-4.2: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
[ 233.607504] usbcore: registered new interface driver snd-usb-audio
[ 233.743686] MCE: In-kernel MCE decoding enabled.
[ 233.744312] asus-ec-sensors PNP0C09:00: Unknown board family: 0
[ 233.745977] asus-ec-sensors: probe of PNP0C09:00 failed with error -22
[ 233.829738] snd_hda_intel 0000:40:00.1: enabling device (0000 -> 0002)
[ 233.830129] snd_hda_intel 0000:40:00.1: Disabling MSI
[ 233.830366] snd_hda_intel 0000:40:00.1: Handle vga_switcheroo audio client
[ 233.830609] snd_hda_intel 0000:42:00.4: enabling device (0000 -> 0002)
[ 233.883248] iwlwifi 0000:3a:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 233.883510] thermal thermal_zone0: failed to read out thermal zone (-61)
[redacted]
[ 234.016864] clocksource: timekeeping watchdog on CPU19: hpet wd-wd read-back delay of 65231ns
[ 234.017133] clocksource: wd-tsc-wd read-back delay of 131511ns, clock-skew test skipped!
[ 234.033346] iwlwifi 0000:3a:00.0: loaded PNVM version dbd9582f
[ 234.045424] iwlwifi 0000:3a:00.0: Detected RF GF, rfid=0x10d000
[ 234.101311] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.2/0000:40:00.1/sound/card1/input24
[ 234.101602] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.2/0000:40:00.1/sound/card1/input25
[ 234.118657] iwlwifi 0000:3a:00.0: base HW address: 80:45:dd:70:1a:ac
[ 234.152571] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.2/0000:40:00.1/sound/card1/input26
[ 234.152908] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.2/0000:40:00.1/sound/card1/input27
[ 234.203971] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.2/0000:40:00.1/sound/card1/input28
[ 234.204269] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.2/0000:40:00.1/sound/card1/input29
[redacted]
[ 234.687745] intel_rapl_common: Found RAPL domain package
[ 234.687746] intel_rapl_common: Found RAPL domain core
[ 234.869325] systemd-journald[3418]: Received client request to flush runtime journal.
[ 235.011221] clocksource: timekeeping watchdog on CPU21: hpet wd-wd read-back delay of 989720ns
[ 235.011726] clocksource: wd-tsc-wd read-back delay of 1056977ns, clock-skew test skipped!
[ 235.015194] audit: type=1400 audit(1668473150.388:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=3853 comm="apparmor_parser"
[ 235.766152] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 235.766383] Bluetooth: BNEP filters: protocol multicast
[ 235.766387] Bluetooth: BNEP socket layer initialized
[ 235.851814] tun: Universal TUN/TAP device driver, 1.6
[ 235.895564] NET: Registered PF_ALG protocol family
[ 236.049813] vboxdrv: Found 32 processor cores
[ 236.050070] nct6775: Using Asus WMI to access 0xc1 chip.
[ 236.060826] nct6775: Found NCT6798D or compatible chip at 0x2e:0x290
[ 236.073807] vboxdrv: TSC mode is Invariant, tentative frequency 3399998127 Hz
[ 236.073981] vboxdrv: Successfully loaded version 6.1.35 r152011 (interface 0x00320000)
[ 236.197737] Bluetooth: hci0: Cannot set wakeable for RPA
[ 236.197999] Bluetooth: hci0: Cannot set wakeable for RPA
[ 236.410578] VBoxNetFlt: Successfully started.
[ 236.410618] bpfilter: Loaded bpfilter_umh pid 4466
[ 236.410772] Started bpfilter
[ 236.424508] VBoxNetAdp: Successfully started.
[ 237.030908] clocksource: timekeeping watchdog on CPU25: hpet wd-wd read-back delay of 725790ns
[ 237.031592] clocksource: wd-tsc-wd read-back delay of 858209ns, clock-skew test skipped!
[ 237.316712] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 237.476365] nvidia-uvm: Loaded the UVM driver, major device number 235.
[ 237.506615] clocksource: timekeeping watchdog on CPU26: hpet wd-wd read-back delay of 527511ns
[ 237.506799] clocksource: wd-tsc-wd read-back delay of 924489ns, clock-skew test skipped!
[ 241.928754] igc 0000:3b:00.0 eth1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 242.036193] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 242.038807] igc 0000:3b:00.0 eth1: Force mode currently not supported
[ 242.259437] NET: Registered PF_PACKET protocol family
[ 243.840301] atlantic 0000:39:00.0 eth0: atlantic: link change old 0 new 1000
[ 243.891143] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 244.692745] igc 0000:3b:00.0 eth1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 247.010675] clocksource: timekeeping watchdog on CPU13: hpet wd-wd read-back delay of 725720ns
[ 247.010677] clocksource: wd-tsc-wd read-back delay of 1056000ns, clock-skew test skipped!
[ 247.279884] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 247.592423] atlantic 0000:39:00.0 eth0: atlantic: link change old 1000 new 0
[ 247.853499] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
[ 247.862185] XFS (nvme1n1p4): Mounting V5 Filesystem
[ 247.873245] XFS (nvme1n1p4): Ending clean mount
[ 247.877669] xfs filesystem being mounted at /var/lib/libvirt/images/pool supports timestamps until 2038 (0x7fffffff)
[ 248.000467] clocksource: timekeeping watchdog on CPU15: hpet wd-wd read-back delay of 166501ns
[ 248.000473] clocksource: wd-tsc-wd read-back delay of 162380ns, clock-skew test skipped!
[ 254.752263] atlantic 0000:39:00.0 eth0: atlantic: link change old 0 new 1000
and Xorg log:
[ 251.505] (--) Log file renamed from "/var/log/Xorg.pid-5437.log" to "/var/log/Xorg.0.log"
[ 251.505]
X.Org X Server 1.20.3
X Protocol Version 11, Revision 0
[ 251.505] Build Operating System: openSUSE SUSE LINUX
[ 251.505] Current Operating System: Linux suse 5.19.8-lp153.3.g14c495f-default #1 SMP PREEMPT_DYNAMIC Tue Sep 13 05:14:37 UTC 2022 (14c495f) x86_64
[ 251.505] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19.8-lp153.3.g14c495f-default root=UUID=7c57285f-d536-4bf2-9c06-87dddeb221f7 default_hugepagesz=1G hugepagesz=1G hugepages=12 iommu=pt video=efifb:off,vesafb:off amd_iommu=on rd.driver.pre=vfio-pci mitigations=auto
[ 251.505] Build Date: 19 October 2022 12:00:00PM
[ 251.505]
[ 251.505] Current version of pixman: 0.34.0
[ 251.505] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 251.505] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 251.505] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 15 01:46:06 2022
[ 251.506] (==) Using config file: "/etc/X11/xorg.conf"
[ 251.506] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 251.506] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 251.506] (==) ServerLayout "Layout0"
[ 251.506] (**) |-->Screen "Screen0" (0)
[ 251.506] (**) | |-->Monitor "Monitor0"
[ 251.506] (**) | |-->Device "Device0"
[ 251.506] (**) | |-->GPUDevice "Device0"
[ 251.506] (**) |-->Input Device "Keyboard0"
[ 251.506] (**) |-->Input Device "Mouse0"
[ 251.506] (==) Automatically adding devices
[ 251.506] (==) Automatically enabling devices
[ 251.506] (==) Automatically adding GPU devices
[ 251.506] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 251.506] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[ 251.506] Entry deleted from font path.
[ 251.506] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/ghostscript/,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 251.506] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 251.506] (WW) Ignoring unrecognized extension "XFree86-DGA"
[ 251.506] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 251.506] (WW) Disabling Keyboard0
[ 251.506] (WW) Disabling Mouse0
[ 251.506] (II) Loader magic: 0x55da5383ed20
[ 251.506] (II) Module ABI versions:
[ 251.506] X.Org ANSI C Emulation: 0.4
[ 251.506] X.Org Video Driver: 24.0
[ 251.506] X.Org XInput driver : 24.1
[ 251.506] X.Org Server Extension : 10.0
[ 251.506] (++) using VT number 7
[ 251.506] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 251.507] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 251.507] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 251.586] (--) PCI:*(63@0:0:0) 10de:1b82:19da:2445 rev 161, Mem @ 0xeb000000/16777216, 0x7fe0000000/268435456, 0x7ff0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[ 251.586] (--) PCI: (64@0:0:0) 10de:1c81:19da:9454 rev 161, Mem @ 0xe9000000/16777216, 0x7fc0000000/268435456, 0x7fd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 251.586] (II) LoadModule: "glx"
[ 251.586] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 251.587] (II) Module glx: vendor="X.Org Foundation"
[ 251.587] compiled for 1.20.3, module version = 1.0.0
[ 251.587] ABI class: X.Org Server Extension, version 10.0
[ 251.587] (II) LoadModule: "nvidia"
[ 251.587] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 251.587] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 251.587] compiled for 1.6.99.901, module version = 1.0.0
[ 251.587] Module class: X.Org Video Driver
[ 251.587] (II) NVIDIA dlloader X Driver 515.65.01 Wed Jul 20 13:50:46 UTC 2022
[ 251.587] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 251.590] (II) Loading sub module "fb"
[ 251.590] (II) LoadModule: "fb"
[ 251.590] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 251.590] (II) Module fb: vendor="X.Org Foundation"
[ 251.590] compiled for 1.20.3, module version = 1.0.0
[ 251.590] ABI class: X.Org ANSI C Emulation, version 0.4
[ 251.590] (II) Loading sub module "wfb"
[ 251.590] (II) LoadModule: "wfb"
[ 251.590] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 251.590] (II) Module wfb: vendor="X.Org Foundation"
[ 251.590] (II) Loading sub module "ramdac"
[ 251.590] (II) LoadModule: "ramdac"
[ 251.590] (II) Module "ramdac" already built-in
[ 251.590] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 251.590] (==) NVIDIA(0): RGB weight 888
[ 251.590] (==) NVIDIA(0): Default visual is TrueColor
[ 251.590] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 251.590] (EE)
[ 251.590] (EE) Backtrace:
[ 251.590] (EE) 0: /usr/bin/X (xorg_backtrace+0x65) [0x55da535b28c5]
[ 251.590] (EE) 1: /usr/bin/X (0x55da53400000+0x1b6599) [0x55da535b6599]
[ 251.590] (EE) 2: /lib64/libpthread.so.0 (0x7fa675bbb000+0x168c0) [0x7fa675bd18c0]
[ 251.590] (EE) 3: /usr/bin/X (0x55da53400000+0xb7498) [0x55da534b7498]
[ 251.590] (EE) 4: /usr/bin/X (xf86CollectOptions+0x7a) [0x55da5349a6fa]
[ 251.590] (EE) 5: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7fa671d76000+0x46a958) [0x7fa6721e0958]
[ 251.590] (EE)
[ 251.590] (EE) Segmentation fault at address 0x124
[ 251.590] (EE)
Fatal server error:
[ 251.590] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 251.590] (EE)
[ 251.590] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 251.590] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 251.590] (EE)
[ 251.605] (EE) Server terminated with error (1). Closing log file.
Since I’m new, I cannot attach files, so let me know if logs from working system (after disconnecting display from GPU at first slot) could be helpful and I’ll post them separately (too long to add everything in this post)
