Xonar DGX...[Solved]
Hey!!
I recently bought an Asus Xonar DGX! Seems to be a really nice card! But I'm wondering whether it will work with what I have. I have an altec lansing fx3022 speakers and a turtle beach P11 headset. Will they work with the card!?
Thank you!
I don't know a great deal about soundcards, nor much to do with sound systems. But from what I have learnt recently; you should probably test the onboard sound against the DGX. You may not need the soundcard.
Tek video:
https://teksyndicate.com/videos/gaming-audio-myths-avoid-bs-save-your-audio-life
Yeah, after the recent Tek video sound cards seem to be a waste of money and don't improve on most decent on board sound..
It will work, but it won't improve the quality of either of those devices. Buy better speakers/headphones first.
Well there can be a difference but that isn't the primary reason. I do want a new soundcard though since the one I have is nearing 3 years...but my speakers don't work with the one i have now, or one of them doesn't. Can't figure out why.
I went into device manager to change the volume settings on everything but that didn't work so perhaps a new card will be the fix. Also it was only 50 CAD so it wasn't expensive at all. I can always return it if it does nothing for me.
But there won't be a difference. Just trying to save yourself some time. Plug everything into your onboard and update the drivers. It's free and takes 2 minutes to setup.
