Xiaomi Mi A1: Lineage 16 works well
Old crap
Got a Xiaomi Mi A1, unlocked, booted TWRP 3.2.3-1 (seems to work fine)
Installing Lineage 16 gives me ErrorCode:: kInstallDeviceOpenError.
However Lineage 15.1 installs and works fine.
Could someone help figure this out?
Edit:
Lineage recommends that I sideload the ROM but outcome is the same:
Edit2:
Third method:
-flash boot_stock.img
-boot into TWRP (without installing) using fastboot (sudo fastboot boot twrp-3.2.3-1-tissot.img)
-format and wipe
-install lineage 15.1
-boot lineage recovery
-try and update to lineage 16 (nah didn’t work)
Edit3:
So I tried several TWRPs all of them boot loop (except for 3.2.3-1) but I also found this “unofficial” TWRP thats pretty good:
https://github.com/CosmicDan-Android/android_device_xiaomi_tissot/releases
Lineage 16 still doesn’t work, but Lineage is posting newer builds for Tissot almost on a daily basis.
Also I went to wipe Dalvik and Cache and… There Is No Cache???
Cache
Its just not right...
Oh and uh the stock andriod 9 (Pie) (the one that lineage 16 is based on) works fine.
UPDATE:
Lineage 16 works fine here’s what you do to flash your Mi A1:
First the phone:
Settings -> About Phone ->Build Number
tap on build number many times until promt with Developer Options
Goto Developer Options-> Enable Andriod Debugging and OEM Unlock
Next get the stuff:
sudo apt-get update
sudo apt-get install android-tools-adb android-tools-fastboot
Plug your phone in
sudo adb devices
(will probably return)
List of devices attached
  • daemon not running; starting now at tcp:5037
  • daemon started successfully
    893956245677 unauthorized
phone promts USB debugging authorisation, accept it and
sudo adb devices
893956245677 device
Then follow the guide:
https://wiki.lineageos.org/devices/tissot/install
And use the TWRP 3.3.1-0-tissot.img
https://dl.twrp.me/tissot/
After flashing the TWRP recovery, boot into it, format phone, transfer the Lineage zip to the phone, and use TWRP to install the zip.
Did you verify the file isnt corrupt?
Sha256sum checks out, does that mean its fine? Also tested a pervious lineage 16 no luck either.
All the bits need to be there for sha256 to work right?
Also, the phone’s specs say its 32GB but TRWP saids 22GB and lineage 15.1 saids 31% used, 21.92GB free. System is taking up 8.8GB, what the hell is up with that?
A fresh install of ubuntu 18.10 takes 6.5GB.
Yes!
Other than that, I can’t help you. You could report this issue on the XDA forum. I’m sure they’ll help you out :wink:
try to flash latest original rom maybe you’re missing latest ril firmware also check if there are patches for zip signing or smthing
Downloaded the stock Xiaomi software, then I fastboot flashed everything manually, going through the flash bat and images
Screenshot
Booted TWRP, tried to Lineage 16, nah
Xiaomi also give you a flash tool but its for windows, I may try that later.
