XFX TS 750W What SeaSonic OEM is it?
Hello Tek Syndicate forum, Been a while since i posted but i have a question. I am upgrading my CX 500M to a psu that is more reliable and a higher wattage. So i wanted to keep it relativity cheap ( As Cheap as i can for a reliable PSU) so i was gonna go with a Corsair RM 650. But then i found the XFX TS 750 for 100$, ( http://www.ncix.com/detail/xfx-ts-series-750w-single-e1-95616.htm ) Now i know XFX psu's are SeaSonic oem's and i know the the XFX XTR is based on the Seasonic G series. Now this PSU seems to be pretty similar to the XFX XTR. It's gold rated and in the same price range 120$ for the TS (not on sale) and the XTR 140$ (not on sale) the only difference i found is that the TS is not modular. I found no reviews and very little info on the seasonic psu it's based on. So i was wondering if anybody had a idea on what it's seasonic equivalent is. If you are confused by my wording then i will be sure to help explain. Thanks Tek Syndicate fourms.
I believe all XFX PSUs are Seasonic OEM, I don't see why the TS would be an exception. Not sure what it is based on.
